Panasonic TX-32CS510
  • unimatrix93
    • Oct 2021
    • 341
    • Magyarország
    Hello everyone, I would like to ask some help repairing this Panasonic TV.
    The symptoms are the following:
    TV turns on, power LED turns green. The display shows a faint screen with very dim backlight, then turns black, power LED starts flashing red indefinetly.
    The PSU outputs two voltages: 5.5V and 16V
    5.5V is present, while 16v is not on the output pin.
    I started looking for for short, not found any.
    Damaged components like capactirs or diodes, did not find any either.
    So I started measuring around the board, tracking back the missing 16v.
    As you can see, the NCP1234 has the High voltage input, but nothing on the drive output.
    The Mosfets has voltages on the source and gate, but nothing on the drain.
    I managed to find the schematics of the TV, I started examining it but I'm pretty new to these SMPS PSUs.
    Can you please point me the right direction and help me repair this board?
    I couldn't find any cheap ones either to just replace, also I would like to learn repair these kind of circuits too.
  • PanasTC
    Panasonic TC-60CX800U turns off after 2 seconds.
    by PanasTC
    Panasonic TC-60CX800U with Power board: TNPA6060 1P
    The TV starts, the LED lights blink for 2 seconds, and the TV turns off; I tested the voltages on the powerboard, and it looks ok.
    Also, I could see HDM in the top corner for a second.
    Is it possible that the issue is a bad LED light that forces the TV to turn off?​
    11-27-2023, 09:02 PM
  • Vesko356
    by Vesko356
    08-11-2023, 03:27 AM
  • Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
    by Stephen
    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
    03-15-2024, 09:37 AM
    High Pressure Sodium Yard light when air conditioner turns light momentarily turns of
    by sam_sam_sam
    I have had these 70 watt high pressure sodium yard lights for many years now probably at least 15 years or more and there is a protection diode that after several years starts to go bad and when it does this it has momentarily shutting down the light and then a few minutes later it starts working again
    This about the forth time I have fixed this one and you can tell if it the diode or not if it lights up and it only shuts down when the air conditioner turns on then it is the diode
    If it cycling on and off constantly then it is the bulb itself that is the issue
    06-03-2023, 05:24 PM
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
