Samsung ua55ku6000k- tv don't start
  • vampy999
    • Sep 2019
    • 110
    • malaysia
    Can someone help check this bios is working or not? The standby led is blinking but TV don't start and standby led stay red.
    Board model: bn94-10801u
  • vampy999
    • Sep 2019
    • 110
    • malaysia
    Re: Samsung ua55ku6000k- tv don't start
    Nvm, its the screen problem
      09-07-2024, 05:50 AM
    • rju
      Samsung 60" Plasma TV, Blinking Standby LED
      by rju
      A sports bar/restaurant with ~40 Samsung Plasma TVs. This is the 2nd TV that has a blinking standby LED. I'd like to learn how to repair these TVs because I'd guess that over time more and more of them will develop this symptom. My hope is to repair the bad PCB, however if that's not realistic then I'd replace the bad PCB.
      Model PN60F5300AF, Type PN60F5300, Model Code PN60F5300AFXZA
      Upon applying power, the red standby is steady. When I tap the power button, the standby LED immediately blinks twice, then it blinks once ~ every 4 secs. Also, Upon applying power, the...
      07-21-2020, 05:23 AM
    • Crystaleyes
      Brazilian Samsung LT27B350LB w/ BN44 00506A - blinking standby LED
      by Crystaleyes
      Hi all.
      Recently joined the forum as particularly keen to thoroughly learn about SMPS's.
      So, a friend asked if his 27" Samsung LED TV could be fixed.
      The problem being that it would switch off after a few minutes and leave a black screen with a blinking red standby LED.
      After finding one cap shorting out, all of the electrolytic caps were changed.
      With the TV still laying screen down, it was switched on and left playing music and videos for some five hours or so, at which point it was decided to replace the back cover...
      09-20-2021, 06:48 PM
    • K212
      Samsung QE65Q700TATXXC is not starting
      by K212
      my Samsung QE65Q700TATXXC has stopped working recently. It worked fine during the morning, and when trying to start it later the same day it just refused to start.
      The standby LED is working, but nothing happens when pushing the power button, other then the LED blinking once. No picture, no sound, no chime, no relay click. I tried a cold start, and other recommended fixes from Samsung. Nothing worked. Then i even tried to reflash the firmware, but nothing happened, not even flashing of the standby led etc.
      I contacted Samsung support who said it is most...
      07-31-2025, 12:45 PM
    • fuxxy
      Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
      by fuxxy
      This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
      Plug the set in, and it will turn on and functions with no issues.
      After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
      Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
      08-02-2022, 09:44 AM
