Samsung LED TV UA55NU7300k (TV rebooting on startup)
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Hi Guys,
    I got in this set that keeps restarting on switch on. I never get an image, i only see back lights on and off and the startup sound of Samsung and then it starts up all over doing the same thing.
    The set has one big flat ribbon going to the scalar board from the main board. I figured that the set is shutting down because of error feedback signals feeding back to the main board.
    I blanked off a certain section on the ribbon and got the TV to start up but it is a very milky white picture. I experimented blanking off different sections but to no avail.
    I think that the error feedback issue is probably this white milky picture. It's almost like a solarized image. On Samsung it is difficult to find the VGL, VGH, Vcom etc but i did locate some.
    VGH = 25.8V
    VGL = -6.5V
    there was also a 17V not sure if that is the AVDD and also half of that...
    HAVDD = 8.5V
    I could not find the gamma voltages if you know what i mean. These are those voltages that start off like 0.7V, 1.5V, 2.2V and increase until 25V. Like a linear reference of sorts.
    I have tested for shorted caps on the scalar boards but found nothing.
    I have been told by a Samsung agent that the 7000 series are prone to panel failure.
    Is there any advice that someone can offer me on this issue. I am at wits end.... Your advice would be greatly appreciated.
    PS: I can take photos if necessary. I am not at work today but you can let me know.
    Regards
    Angelos
  • etbmikenel
    • Dec 2018
    • 17
    • South Africa
    Re: Samsung LED TV UA55NU7300k (TV rebooting on startup)
    Make sure the cable you are using is not too think when using the tape method.
    It are most definitely faults on the open cells of the panels on the RU/NU/TU 7x00 series TVs. Most RU/NU panels can be resolved using the tape method and some patience.
    Samsung have done revisions to a majority of the panels supplied on these units when performing replacements, oftentimes requiring mainboard replacements in conjunction due to compatibility and stability issues on these units.
      09-07-2024, 05:50 AM
    • TR103
      by TR103
      - it keeps rebooting
      01-22-2025, 04:12 PM
    • plytek
      Samsung QE50Q60TA rebooting
      by plytek
      Hi all.
      I'm trying to fix my Samsung QE50Q60TA TV.
      IT's rebooting every few seconds.
      I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
      Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
      Can anyone suggest what I can test and do to get it working again please?...
      02-08-2025, 06:02 AM
    • unimatrix93
      SAMSUNG UE55TU7002KXXH rebooting
      by unimatrix93
      Hello everyone, I'm working on a Samsung TV that constantly rebooting.
      MB/PSU unit: BN9654185QE
      It loads up to the main menu then as soon as the backlight goes brighter it reboots.
      First I suspected the LCD panel, so a disconnected the LCD display from the mainboard but did the same thing.
      Then I removed the backlight connector which only delayed the bootloop by a minute maybe, I know it because I test it with the remote, it does gives the menu sounds a bit longer.
      Also I have to note, that the MB/PSU combo gives out a very noticible...
      04-07-2025, 09:49 AM
      09-06-2024, 11:40 PM
