advices for repairing Sony Bravia 32EX600 after lightning strike
  • pbig
    • Apr 2019
    • 5
    • France
    hi everyone,
    my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
    On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
    - the 450V/150uF capacitor voltage when plugged is normal at 394V
    - from connector CN6150 (15 poles)
    STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged the CPU board with audio/video/antenna IO
    1 (STBY) = 3.3V
    2 (AC OFF DET = 0.87V
    3 (POWERON) = 3.3V
    4 (AUDIO 12V) = 12.77V
    5 (AUDIO 12V GND) = 0V
    6+7 (REG12V GND) = 0V
    8 (REG 12V) = 12.77V
    10 (BL ERR) = 0.1V
    11 (BL ON) =3.3V
    12 (DIMMER) =0V
    13 (disconnected)
    14 (TCON VCC12V) = 0V
    15 (RCON ON) = 0V
    Still no backlight. Keeping the reference at the chassis, I made measure of LED supply voltages :
    -OUT1/-OUT2 (CN6801) ~ 5V slowly decreaing
    +OUT1/+OUT2 (CN6800) 91.6V stable
    Are these correct ?
    No component seems roasted on the mainboard, I have not checked T-CON board. Any advice is welcome. Thanks in advance,
    Pierre
  • PopsCaps
    Sony Bravia KDL-40V2500 that will not power on
    by PopsCaps
    I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
    I do not hear any sound and I cannot see any backlight.
    I have tried disconnecting every cable on each board one at a time to see if anything changes.
    The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
    My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
    03-25-2025, 11:23 AM
  • justin35
    Sony bravia kdl-43w755c - boot loop
    by justin35
    i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
    from what i read online it looks to be an emmc issue…
    i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
    i took out the board and say an samsung 16gb emmc
    i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
    i could try to put one instead of the 16gb one, but will it work?
    where do i get the software from?
    any help will be much appreciated!...
    03-06-2024, 12:26 PM
    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic
    Sony Bravia 22" LED Full HD TV KLV-22P402B Schematic...
    10-16-2024, 05:15 AM
  • Bardou Kari
    HP EliteBook 840 G6 – no power after lightning strike
    by Bardou Kari
    I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
    – Charger is OK and 19V is present at the motherboard.
    – No charging LED, no fan, no reaction.
    – I don’t see any 3.3V or 5V near the coils.
    – Battery is unplugged.
    – I’m new to board repair but can use a multimeter.
    I added a clear photo of the board.
    Any idea where to start or what to check next?
    Thanks a lot for your help!...
    07-01-2025, 10:45 AM
  • Spc.
    Sony Bravia KD43XF7596BAEP - Android no picture
    by Spc.
    Greetings everyone.
    I also have Sony Bravia, model:
    Sony Bravia KD43XF7596BAEP - Android.
    What happend is that image dissapeared while we were watching tv.
    Diagnostics:
    1. TV turns on, no errors
    2. Backlight turs on, no errors
    3. Power indicator turns on, white color, no errors
    4. Menu works on android, you can hear sound while switching channels
    5. Volume up and down works via TV remote and via buttons
    6. Tunner works, HEVC / MPEG-4 decoder works
    7. I get audio from channels
    8. No picture is present,...
    05-19-2022, 04:28 AM
