Samsung 58M6120kxzl versión:DA01
  • Telemundo
    Ray gee
    • Jun 2023
    • 10
    • Colombia
    Hello, could you me with file please, thanks
    Model:KANT_M_BUILL_IN
    CODE:BN-02568B
    MODEL:BN41-02558
    DATE:2017
    BN97-13471F
    BN94-12695T
    IC1604 25Q40CL
  • lotas
    • Jan 2016
    • 4571
    • Russia
    Re: Samsung 58M6120kxzl versiónA01
    CODE:BN-02568B
    MODEL:BN41-02558
    DATE:2017
    BN97-13471F
    BN94-12695T
    IC1604 25Q40CL
    You need to post your non-working dump, I will fix it, other dumps will not work for you.
    • Telemundo
      Ray gee
      • Jun 2023
      • 10
      • Colombia
      Originally posted by lotas
      you need to post your non-working dump, i will fix it, other dumps will not work for you.
      • lotas
        • Jan 2016
        • 4571
        • Russia
        Your firmware is working.
        • Telemundo
          Ray gee
          • Jun 2023
          • 10
          • Colombia
          The tv restarts, I know remove the main connector and the LEDs turn on well I know the display disconnects and it remains the same how can I activate the main without the TV source I know place the point fb_trdy_3 to pin 1 of the CN1300 connector, I appreciate your help.
          • lotas
            • Jan 2016
            • 4571
            • Russia
            fb_trdy_1 - fb_trdy_3
            • Telemundo
              Ray gee
              • Jun 2023
              • 10
              • Colombia
              Re: Samsung un58M6120kxzl versiónA01
              Yes, I know he did that but it still doesn't work, it keeps restarting, the following is how I test the main without the source, what to do, I know, put the 12 vol to the main and what other point must be polarized in the main
              • lotas
                • Jan 2016
                • 4571
                • Russia
                It is not clear, you are rebooting if one left cable, one right cable, both cables (left and right) are disconnected.
                • Telemundo
                  Ray gee
                  • Jun 2023
                  • 10
                  • Colombia
                  • Telemundo
                    Ray gee
                    • Jun 2023
                    • 10
                    • Colombia
                    The TV restarts with all the cables placed, those of the source and the main TV was on and it turned off and it stayed in that mode restarting
                    • Telemundo
                      Ray gee
                      • Jun 2023
                      • 10
                      • Colombia
                      Thank you very much for your collaboration, the problem has been solved, the 12 volt fuse on the motherboard was open f23_UT
                        09-07-2024, 05:50 AM
                      • GeckoGreen
                        Samsung service bulletin: need firmware file for PN63C550 TV
                        by GeckoGreen
                        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                        Will you please help me get the [2D63]LOGIC.bin file for my TV?
                        05-17-2025, 02:47 PM
                        09-06-2024, 11:40 PM
                        09-06-2024, 08:40 PM
