Any guesses on what's wrong with this Vizio VP42? The image is there, but it is just washed out.
Vizio VP42 Plasma - Washed out Image
Re: Vizio VP42 Plasma - Washed out Image
If that is indeed a pinkish tint, and not the camera angle, then I'd say it's time to open it up and see what's what.
Does changing brightness or contrast make any difference? Is there a menu "reset" option to return to factory settings?Comment
Brightness/contrast didn't make a difference. Reset didn't help either. I am fully expecting to open this up, I was mainly inquiring to see if someone could help me pinpoint which board could be causing these issues. Thanks for your help so far.Comment
The drill is to open the set up and take a picture or two.. I prefer a single picture covering all of the back of the TV. This shows the relationship between the various boards.
There should be several stickers on the back of the panel. One of these should be the model number of the panel. Another will be the voltages required by the panel. From those you should be able to identify the manufacturer of the panel. Otherwise, check the part number on the white labels on the Sustain cards (cards with big heat sinks on each side of the TV.
Wizard's wisdom says that a pink tint is a plasma panel nearing end of life, although I would pull up the service menu to verify the hours on the panel before writing it off.
Interesting item for sale on eBay Looks familiar.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Originally posted by PlainBillWizard's wisdom says that a pink tint is a plasma panel nearing end of life, although I would pull up the service menu to verify the hours on the panel before writing it off.
Note to self- do not buy plasma set.Comment
If you turn it on in the morning when you get up, and it stays on until you go to bed, 10,000 hours is about 1 1/2 years. If you watch TV for an average of 5 hours a day (I'm retired and can't imagine watching TV that much), that works out to over 5 years. About a year ago I fixed a 4 year old plasma TV which my wife 'confiscated'. She has it on for background noise while grading homework, etc. It currently has more than 20,000 hours on it, noticeable 'pillars' from watching SD shows, and still has very good color.
Don't forget, in addition to the user brightness, contrast, and tint controls there are service adjustments that allow adjusting out any panel-wide color changes.
All of the current HDTV technologies have problems.
DLP TVs use a high intensity lamp that is rated to last 4000 hours, and has a list price ranging from $375 to over $600. Third party bulbs are available for about $100 but may or may not match the ballast. Per Wizard, the ballast is tuned to the characteristics of a particular brand of lamp.
LCD TVs use CCFLs which have a limited life; the inverter is also prone to failure. I've got a 37" Sharp on the bench that has 18 CCFLs. Fortunately the CCFLS aren't the problem, but how would you like to replace all 18 of them? Or replace only one and have a stripe across the screen?
Now LCDs are going to LEDs for backlights (at a considerable premium in price). That takes care of the problems with inverters, but how many hours are you going to get out of them before the LEDs start failing? Matching intensity and color on those are going to be fun.
Plasma displays show signs of aging. Earlier this year I repaired two plasma TVs that used the same panel as the Vizio VP42. One had 10,000 hours, and had color variations that were noticeable on a pure white screen. The other had under 700 hours and was noticeably more vivid.
As I indicated earlier, I have a plasma with 20,000 hours that has noticeable pillars from extensive viewing of SD broadcasts. My wife swears the display beats any LCD TV she has ever seen. I don't care, I see a happy wife.
Originally posted by PlainBillWell, I have seen plasma panels listed. The going rate seems to be about $150 - $200.
At those kind of costs, after 3 years, it really is better to buy the new set.
My wife swears the display beats any LCD TV she has ever seen. I don't care, I see a happy wife.VERY IMPORTANT
This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:20 PM
by CharleydWhen plugged in, Vizio V585-H11 powers up, the standby light flashes 18 times, but there is simply no image on the screen. I can see a glow from the backlights, and the sound works. Tearing in to it, all voltages coming out of the Power Supply appear reasonable. I suspect a bad panel, so I disconnect one of the two wide ribbon cables between the T-Con board and the panel. Now the TV starts up fine without the 18 flashes, and with a good image on 1/2 of the screen. If I switch to the other ribbon cable, the TV again starts up fine, but now with a good image on the other 1/2 of the screen. Still...
Assuming...7 Photos -
Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
The TV was stuck on the logo and I couldn't access the update menu.
I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
The image result was good, but the image is inverted.
The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in... -
by piershsMy 2001 Toshiba 50WP16 50" plasma TV has, after 20 years of trouble-free service, developed a wierd fault in the last 14 days during normal viewing - with no loud bang or smoke or any other excitement.
Every 15-30 secs the right hand half of the image has a "glitch" for about 1 second before reverting to normal. The glitch has two forms and also depends on the aspect ratio setting (see photos):- 16:9 either a) a visible seam between LHS and RHS of impage or b) LHS image duplicated on RHS (photos 16x9)
- 4x3 either a) no image on RHS or b) RHS image offset by 1/6th
- Loading...
