mitsu plasma "jailbars"
  • briander plasma
    • Sep 2010
    gentlemen,
    in servicing a mitsubishi plasma model pd-5010, problem is vertical lines covering half screen only, several noted. they extend from top and bottom of screen to one half of screen only. flat connector strips from buffer boards are in some cases showing a burnt rectangular chip which extends across the
    strip from left to right, burnt area is on 'chip" but some dont show 'area at all.
    is the problem fixable? we feel that buffer boards may be problem but the
    black chip has us puzzled what is it" no other problems noted tv works fine otherwise.
  • Yanleb
    Schematic or datasheet for Plasma TV buffer chip
    by Yanleb
    I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
    So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
    Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
    05-18-2022, 01:36 PM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • Bad_Boards
    LG Plasma TV Bad Y Buffer Replacement
    by Bad_Boards
    Background:
    I have a LG 50PA550 Plasma TV which stopped displaying a picture. The sound works just fine. The outputs of the power supply board were within 2% of the expected values. After removing the Y top buffer the bottom half of the TV started working.
    Question:
    Do I have to order both a Y-Buffer and Y-Sustain board to fix this?
    Could I somehow check the Y-Sustain board to see if there was any damage done to it?
    04-07-2021, 09:39 PM
  • jm1234
    Panasonic plasma TX-P42ST50 - 6 blinks
    by jm1234
    anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
    It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
    I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
    I checked that board for any obvious faults...
    05-22-2024, 06:59 AM
