Samsung UE43RU7092U
  • YellowJacket
    • Dec 2020
    • 107
    • Slovakia
    Samsung UE43RU7092U
    Hi friends,
    I would ask for a little help with diagnosing this TV. Got it from friend, with no picture. There is a backlight, but TV is restarting approximately every 5 sec.
    I found out, that if I remove either one, or both flex cables connected from main board, to panel, TV starts, I can hear samsung sound, backlight is ON all time, but there is no picture ( when at least one flex cable is connected of course ). I believe, it is not firmware related ( or am I wrong? ), but I have no idea, why TV starts with connected only first, or only second flex cable - was expecting short in panel, so one of that flex cables should be shorted to ground, and so I should see half picture with 'healthy' flex connected. But obviously, this is not that case. Long story short - TV cannot start only when both flex are connected.
    Any ideas, what can I check? I measured resistance to ground of each coil on main board, here is result:
  • lotas
    • Jan 2016
    • 4899
    • Russia
    Re: Samsung UE43RU7092U
    You need to connect these two points with a jumper, then you can determine which half is not working.
    • YellowJacket
      • Dec 2020
      • 107
      • Slovakia
      Nice, I had no idea, I should short some pins. Do you know it from your experience, or its some well known procedure?
      After shorting them together, I can see half picture in both cases, but with lower flex removed, there are many vertical lines, so picture is corrupted. I am going to make some measurements on that side of the board and if I am lost, will ask again.
      Thanks for now, lotas.
      • YellowJacket
        • Dec 2020
        • 107
        • Slovakia
        // UPDATE: 8 pins CKVx on right panel side was masked, TV is showing picture again. I hope, it will last long. Thank you lotas for kicking me right direction.
        • Christescuu
          • Sep 2023
          • 3
          • Romania
          Hello, i have the same issue with the tv, removed the right side connection and with the jumper it shows half of the screen. Can you tell me witch 8 pins you masked? Thanks a lot
          • EazyBone
            • Jun 2023
            • 1362
            • United states
            It's just trial and error. Stick some tape, plug it in. Each short is usually different but it's usually on left or right side not generally in middle
            • Christescuu
              • Sep 2023
              • 3
              • Romania
              Thank you for the quick response 😊 . Yep I'm trying for almost half an hour in different positions. But now when im re-reading the thread it gives me a little question...when i remove the right flex and put the jumper it shows a perfect half of screen...on the left flex it shows no picture when i put the jumper. I will only mask for the right side flex? Or i should start trying also on the left one? Thank you in advance!
              • lotas
                • Jan 2016
                • 4899
                • Russia
                It is necessary to mask on the side that does not work, does not show.
                • Christescuu
                  • Sep 2023
                  • 3
                  • Romania
                  Evrika! Works perfectly 😁
                  • EazyBone
                    • Jun 2023
                    • 1362
                    • United states
                    What is it that your jumping and why does this work? Is this something that works on all screens or is this specific to this tv?
                    • lotas
                      • Jan 2016
                      • 4899
                      • Russia
                      Here, depending on your luck (maybe a perfect picture will come out, maybe with thin stripes, artifacts, or maybe nothing will work out).
                        • 12331
                        • U.S.
                        I believe he's asking if this jumping works on all tv's or just this model or brand.
                        • EazyBone
                          • Jun 2023
                          • 1362
                          • United states
                          Yea I'm trying to learn what is being jumped as part of the picture is blocked by the 13k and what tvs this would work for. I'm learning how to problem solve them quicker so I can quit wasting my time in certain areas. This seems like it could be useful for that
                            09-06-2024, 06:20 PM
                            Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            Samsung Galaxy Book Flex NP930QCG Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP930QCG Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930QCG boardview and NP930QCG schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                            09-07-2024, 12:40 AM
                            09-06-2024, 11:40 PM
                            Samsung Galaxy Book Flex NP930QCGI Hybrid (2-in-1) Specification for Upgrade or Repair
                            This specification for the Samsung Galaxy Book Flex NP930QCGI Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP930QCGI boardview and NP930QCGI schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 10:50 PM
