Prima PH-42T7
  • pelota
    • Sep 2010
    • 7
    Prima PH-42T7
    I recently got a Prima PH-42T7 plasma TV, which has a Samsung S42AX-Y001 panel. This thing powers on and you get a picture but you get horizontal black and red lines over the screen except for the bottom 2 inches. I assume this means the Y-Buffers are going? I can get another Tv of this model that powers on but with no picture, from do some reading I assume this might need a Y-Sustain board. Now for the question. If both assumptions are correct. What would be the odds of getting a good set of buffers out of the second TV. Or if the Y-Sustain goes how often does it take the buffer boards with it?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Prima PH-42T7
    I'd say the chances are slim. One common failure sequence is a buffer shorts, taking out the Y-Sustain. Check out the first March post in this blog.
    Depending on the cost of the second set, it would be instructive to swap the Y-Sustain and Y buffers between sets (do this as a unit).
    PlainBill
    • xDonny
      • Nov 2010
      • 5
      Re: Prima PH-42T7
      hey i have the same problem, i was looking around and saw that it was a problem with a buffer board or something? is there a way to fix this on a budget? I just got this tv for free and would like it for my bedroom
      • xDonny
        • Nov 2010
        • 5
        Re: Prima PH-42T7
        why is it that people just replace the sustain boards? can you not fix it?
        • xDonny
          • Nov 2010
          • 5
          Re: Prima PH-42T7
          alright so i think i mega-frigged it up, when i got this tv i had to replace a fuse that somebody took out, so i tried to replace another and the one i put in it was a 36v by accident and it blew the fuse, and now it only turns on for a second or two then turns off, i'm leaving it unplugged overnight because i remember hearing something about leaving it to discharge but anyway, if anybody has any idea how i can fix this without buying the stupid $200 boards in the back tell me
          • PlainBill
            • Feb 2009
            • 7034
            Re: Prima PH-42T7
            You don't have to buy new boards. There are a number of firms that rebuild them. Here are the economics: A buffer contains 6 chips that cost $8- $10 each. These ICs have over 100 pins so removing the old and installing the new is very delicate. In general, the rebuilder will replace all ICs. Rebuilding each buffer costs $80 - $90. If a buffer shorts it usually shorts a transistor on the Y-Sustain board. That transistor is relatively inexpensive (under $10), but requires a hot air system to remove it. Sometimes the hybrid shorts. The hybrid costs $40, and is tricky to replace. The going rate for a rebuild of all boards is $250.
            PlainBill
            • xDonny
              • Nov 2010
              • 5
              Re: Prima PH-42T7
              I havn't got that kind of money
              • PlainBill
                • Feb 2009
                • 7034
                Re: Prima PH-42T7
                And if you had that kind of money I would have recommended that you NOT use it to repair this TV. New 42" plasma TVs are selling for $400-$450. Used 42" Plasmas are going for under $300.
                PlainBill
                • xDonny
                  • Nov 2010
                  • 5
                  Re: Prima PH-42T7
                  I want to fix this on my own, if i post pictures of the boards can you circle the bits that need replacing? i can use a heat gun to replace them
                  • pelota
                    • Sep 2010
                    • 7
                    Re: Prima PH-42T7
                    Thought I would report back on the results. Bought a set of "New" buffers from some guy in China, kinda cheap. Arrived and actually looked new. Installed been running fine about 4 months
                    • ronklo
                      Re: Prima PH-42T7
                      Can you share where you got the boards from? I have 2 of these TV's that turn on & off, but no picture or sound, but do pass a picture from Cable or AV input, through to the AV output (but no sound). I've just started tinkering with TV's but in electronics for 30 so hoping repair shouldn't be too tough.
                      • CoppellTVRepair
                        • 39
                        Re: Prima PH-42T7
                        Just a word of caution:
                        http://blog.coppelltvrepair.com/2012...upper-and.html
                        Just for the record a pair of *new* buffers , meaning brand new, SAMSUNG OEM with the 4 ICs (manufactured on or after 2010) is $130.
                        Of course that can always change, but it's been somewhat reliably holding for the past year or two.
                        We and others occasionally sell used 6-IC buffers on eBay; they go usually below $40 a piece, in fact the last time I think one of them sold for about $12 or so.
                        I am not recommending avoiding China in general - after all that's where most of what's in the official US stores comes from - but you should definitely think twice about this particular set of boards.
                        • howardc64
                          by howardc64
                          07-24-2025, 05:17 PM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • Yanleb
                          Schematic or datasheet for Plasma TV buffer chip
                          by Yanleb
                          I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
                          So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
                          Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer....
                          05-18-2022, 01:36 PM
                        • legg
                          LG 42PC3 buffer output doesn't follow YSUS
                          by legg
                          LG42PC3D -UD originally with green lamp but no display or audio.
                          Owner says was working, then went 'pop'.
                          All 5V caps bulging. replaced.
                          All PSU output voltages within spec but -Vy is low on YSUS.
                          One of three parallel fets between SUS_OUT and SUS_DN is zenering,
                          eventually shorts DG. Replaced all 3 - -Vy now OK.
                          Y scan buffer test point does not follow YSUS output below -50V
                          Note: This unit seems to expect YSUS output to park at -Vy in between
                          drive signal pattern periods. A replacement drive signal board confirms this....
                          11-18-2021, 11:49 AM
                        • howardc64
                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                          by howardc64
                          • Prior owner tried a replacement main board. No difference.
                          • Samsung 2x red blinking standby LED = panel fault
                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                          07-19-2025, 10:54 PM
