I recently got a Prima PH-42T7 plasma TV, which has a Samsung S42AX-Y001 panel. This thing powers on and you get a picture but you get horizontal black and red lines over the screen except for the bottom 2 inches. I assume this means the Y-Buffers are going? I can get another Tv of this model that powers on but with no picture, from do some reading I assume this might need a Y-Sustain board. Now for the question. If both assumptions are correct. What would be the odds of getting a good set of buffers out of the second TV. Or if the Y-Sustain goes how often does it take the buffer boards with it?
Prima PH-42T7
Re: Prima PH-42T7
I'd say the chances are slim. One common failure sequence is a buffer shorts, taking out the Y-Sustain. Check out the first March post in this blog.I recently got a Prima PH-42T7 plasma TV, which has a Samsung S42AX-Y001 panel. This thing powers on and you get a picture but you get horizontal black and red lines over the screen except for the bottom 2 inches. I assume this means the Y-Buffers are going? I can get another Tv of this model that powers on but with no picture, from do some reading I assume this might need a Y-Sustain board. Now for the question. If both assumptions are correct. What would be the odds of getting a good set of buffers out of the second TV. Or if the Y-Sustain goes how often does it take the buffer boards with it?
Depending on the cost of the second set, it would be instructive to swap the Y-Sustain and Y buffers between sets (do this as a unit).
PlainBillLast edited by PlainBill; 09-22-2010, 12:11 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
Re: Prima PH-42T7
hey i have the same problem, i was looking around and saw that it was a problem with a buffer board or something? is there a way to fix this on a budget? I just got this tv for free and would like it for my bedroomAttached Filesif you find these attachements useful please consider making a small donation to the site
Re: Prima PH-42T7
alright so i think i mega-frigged it up, when i got this tv i had to replace a fuse that somebody took out, so i tried to replace another and the one i put in it was a 36v by accident and it blew the fuse, and now it only turns on for a second or two then turns off, i'm leaving it unplugged overnight because i remember hearing something about leaving it to discharge but anyway, if anybody has any idea how i can fix this without buying the stupid $200 boards in the back tell meComment
Re: Prima PH-42T7
You don't have to buy new boards. There are a number of firms that rebuild them. Here are the economics: A buffer contains 6 chips that cost $8- $10 each. These ICs have over 100 pins so removing the old and installing the new is very delicate. In general, the rebuilder will replace all ICs. Rebuilding each buffer costs $80 - $90. If a buffer shorts it usually shorts a transistor on the Y-Sustain board. That transistor is relatively inexpensive (under $10), but requires a hot air system to remove it. Sometimes the hybrid shorts. The hybrid costs $40, and is tricky to replace. The going rate for a rebuild of all boards is $250.alright so i think i mega-frigged it up, when i got this tv i had to replace a fuse that somebody took out, so i tried to replace another and the one i put in it was a 36v by accident and it blew the fuse, and now it only turns on for a second or two then turns off, i'm leaving it unplugged overnight because i remember hearing something about leaving it to discharge but anyway, if anybody has any idea how i can fix this without buying the stupid $200 boards in the back tell me
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Re: Prima PH-42T7
Can you share where you got the boards from? I have 2 of these TV's that turn on & off, but no picture or sound, but do pass a picture from Cable or AV input, through to the AV output (but no sound). I've just started tinkering with TV's but in electronics for 30 so hoping repair shouldn't be too tough.Comment
Re: Prima PH-42T7
Just a word of caution:Can you share where you got the boards from? I have 2 of these TV's that turn on & off, but no picture or sound, but do pass a picture from Cable or AV input, through to the AV output (but no sound). I've just started tinkering with TV's but in electronics for 30 so hoping repair shouldn't be too tough.
http://blog.coppelltvrepair.com/2012...upper-and.html
Just for the record a pair of *new* buffers , meaning brand new, SAMSUNG OEM with the 4 ICs (manufactured on or after 2010) is $130.
Of course that can always change, but it's been somewhat reliably holding for the past year or two.
We and others occasionally sell used 6-IC buffers on eBay; they go usually below $40 a piece, in fact the last time I think one of them sold for about $12 or so.
I am not recommending avoiding China in general - after all that's where most of what's in the official US stores comes from - but you should definitely think twice about this particular set of boards.Comment
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by YanlebHi all,
I'm interested in understanding how a buffer board chip is working. I know there's about 90 outputs per chip to the plasma panel, but I'm more interested to know about the input pins. I guess that some of them are address pins, but I want to know more.
So far I've found nothing at all. I haven't found any datasheet about the various buffer chips, and I haven't found any schematic for the buffer board using them (Y Buffer Board in Samsung's terminology).
Any information will make me happy. It can be from any buffer chip or plasma TV manufacturer.... -
by leggLG42PC3D -UD originally with green lamp but no display or audio.
Owner says was working, then went 'pop'.
All 5V caps bulging. replaced.
All PSU output voltages within spec but -Vy is low on YSUS.
One of three parallel fets between SUS_OUT and SUS_DN is zenering,
eventually shorts DG. Replaced all 3 - -Vy now OK.
Y scan buffer test point does not follow YSUS output below -50V
Note: This unit seems to expect YSUS output to park at -Vy in between
drive signal pattern periods. A replacement drive signal board confirms this....11-18-2021, 11:49 AM -
by howardc64
- Prior owner tried a replacement main board. No difference.
- Samsung 2x red blinking standby LED = panel fault
- Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
- Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
- Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
- Loading...
