Samsung UE55MU6102K IC1604 dump needed - TV don't start
  • totof
    • Feb 2017
    • 157
    • france
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H
    Here is the dump of my IC1604.
    Does anyone have the binary for this TV model?
    Thank you.
  • lotas
    • Jan 2016
    • 4609
    • Russia
    Re: Samsung UE55MU6102K IC1604 dump needed - TV don't start
    This dump is working, I threw it off for you to check and you had the same thing, this dump is native or has already been rewritten by you or someone else, the behavior of the TV is as if a dump was recorded with a different version of the software. If the 25Q40 firmware flies, then the TV will not turn on at all, the standby indicator will not even light up.
    • totof
      • Feb 2017
      • 157
      • france
      Thank you lotas for your response.
      The standby led is always red, it only flashes once when I try to turn on the tv.
      After starting the TV, with your file 25q40, the content is not exactely the same : from address 0006F000 to 0006F17D 0xFF are replaced by other values and from address 00070000 to 00070DDF initial values are replaced by 0xFF
      However I also put status register to 0x88 and 0x42 after writing using NeoProgrammer 2.2.0.10
      I don't know the history of this TV, I don't think it has ever been reprogrammed by anyone but I can't be sure.
      If so, what would it take to fix it?
      • lotas
        • Jan 2016
        • 4609
        • Russia
        In this "MU" series and not only in this one, the software version in SPI 25Q40 and in eMMC should match, if the version does not match, then it will approximately behave like yours, select different versions (there are only 6-7 of them), diagonal and the model difference does not matter, the main thing is that the series be "MU".
        • totof
          • Feb 2017
          • 157
          • france
          Thanks.
          Is there a simple solution to program eMMC ? it will be interesting for me
          I'm looking for a UE43MU6105K motherboard and I will try with this card.
          • lotas
            • Jan 2016
            • 4609
            • Russia
            eMMC can only be flashed with a programmer, and if you flash eMMC, then you need to flash it with the entire working kit (eMMC, SPI 25Q40, EEPROM 24C512).
            If you install another motherboard, then you need to rewrite or rearrange spi 25q80 - this is T-CON (it is responsible for your panel.
            • totof
              • Feb 2017
              • 157
              • france
              OK.
              I will try to dump the spi 25q80 of the original motherboard and rewrite it on the new motherboard.
              • totof
                • Feb 2017
                • 157
                • france
                I have found another motherboard BN41-02568B / BN94-12643A for TV UE43MU6105K (not UE55MU6102K).
                I see that some resistors are different from the two motherboards. Do you think it could works this my panel if a only rewrite my 25q80 on the other mothboard ?
                • lotas
                  • Jan 2016
                  • 4609
                  • Russia
                  Yes, it happens on the boards in the area of LVDS connector that they put optional resistors or jumpers (zero resistors) for certain panels.
                  • totof
                    • Feb 2017
                    • 157
                    • france
                    Thank you lotas, I will try the other motherboard
                    • lotas
                      • Jan 2016
                      • 4609
                      • Russia
                      It is better to find "55" for your diagonal or very close to "49".
                      • totof
                        • Feb 2017
                        • 157
                        • france
                        okay it's safer and I don't want to do anything stupid :-)
                        • totof
                          • Feb 2017
                          • 157
                          • france
                          I found a motherboard but for another model UE55MU6645 TV.
                          Now the TV starts well and, having not reprogrammed the SPI 25Q80, I have vertical lines on the image and the colors are not beautiful.
                          If I understood correctly, now I have to copy the contents of SPI 25Q80 from the original motherboard to the new one?
                          • totof
                            • Feb 2017
                            • 157
                            • france
                            I put the original SPI 25Q80 (from mainboard UE55MU6105) on the new mainboard (from UE55MU6645) and now the image is perfect.
                            Problem solved
                            • lotas
                              • Jan 2016
                              • 4609
                              • Russia
                              Problem solved
                              You did everything right, that you bought from 55 diagonals and threw the t-con firmware.
                              • totof
                                • Feb 2017
                                • 157
                                • france
                                Once again thank you lotas for your advice.
                                • Telemundo
                                  Ray gee
                                  • Jun 2023
                                  • 10
                                  • Colombia
                                  hello,could you help me with file please,thanks Samsung 58M6120k versión DA01 code BN41-02568B/BN94-126
                                  • Telemundo
                                    Ray gee
                                    • Jun 2023
                                    • 10
                                    • Colombia
                                    hello,could you help me with file please,thanks Samsung un58M6120kxzl versión DA01
                                    Code BN41-02568B/BN9412695T
                                    Ic 1604 25Q40CL
                                    • RomainO
                                      • Jan 2021
                                      • 6
                                      • france
                                      totof lotas : I am reading the 2 first posts of this thread and I have the feeling that lotas provided a working .bin to totof, but I cannot find it linked.
                                      Can one of you provide me this bin ? I have the exact same problem with the exact same TV model.
                                      • lotas
                                        • Jan 2016
                                        • 4609
                                        • Russia
                                        You need to post your non-working dump, I will fix it.
                                        • jeangonbay
                                          Samsung UE43MU6105K IC1604 dump needed - TV don't start
                                          by jeangonbay
                                          Could you help me,I have a Samsung UE43MU6105K with the following problem, dead TV, when I disconnect the main power supply to logic board, the leds light up.
                                          The model of my TV is UE43MU6105K
                                          Main Board: BN41-02568B
                                          BN94-12007Y
                                          Could you help me to repair the dump please. Thank you.
                                          02-16-2024, 05:46 AM
                                        • juas
                                          Samsung UN40MU6290FXZA IC1604 dump Help
                                          by juas
                                          Could you help me... I have a Samsung with the following problem, dead TV, I disconnect the main power supply and the leds light up. I know it is a problem in the firmware in the IC SPI Flash W25Q40CL (IC1604)
                                          TV model: UN40MU6290FXZA
                                          Version: FB02
                                          Main Board Sticker: BN94-12640X
                                          Same issue like this post: https://www.badcaps.net/forum/troubl...3f-ic1604-dump
                                          I tried fixed bin but doesnt...
                                          03-21-2024, 10:36 PM
                                          09-07-2024, 05:50 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
