Sony Trinitron KV32FV27 Suddenly Dimmed
  • R_J
    • Jun 2012
    • 9588
    Re: Sony Trinitron KV32FV27 Suddenly Dimmed
    If the resistor is open, replace it, that could be the only problem. It is likely the resistor just went open on its own and not a fault with the ABL circuit but would cause the brightness to be effected like in your picture
    • cmonkey
      • Apr 2023
      • 58
      • Unitied States
      Thanks for the input, I'll post back the results next week when I get a new one in. The more I thought about how I saw how it failed, the more some simple part like a resistor makes sense since it was so sudden.
      • cmonkey
        • Apr 2023
        • 58
        • Unitied States
        I'm glad to report that replacing that one resistor fixed the problem. I couldn't believe it at first, but yep it's good now. I've had it running for about an hour and it seems fine. There is a sort of green flash when the set first turns on, but it quickly goes away so I dunno if that will become an issue but for now I can enjoy this amazing TV and have learned a lot from this repair. Thanks to everyone who posted and I hope this can help someone in the future.
        • R_J
          • Jun 2012
          • 9588
          I believe that flash you see is normal on a sony as it checks the crt current, Green is the predominant color at about 59% It might be more noticeable if the G2 screen control is adjusted a bit too high. other than that it looks like you have it fixed.
          • cmonkey
            • Apr 2023
            • 58
            • Unitied States
            Ugh. Well that was short lived.
            After using it for maybe 6-8 hours the past few days with no issues, today the picture started warping and wobbling everywhere like someone was messing with the geometry settings. The sound also started getting distorted. I immediately turned it off and let it sit for a few minutes and turned it back on. Now there is no picture at all and a faint buzzing from the speakers.
            I don't think there is high voltage either because I don't feel any static on the screen and I don't hear it. When I push the power button I hear a click from the power supply and then after a few seconds I hear a buzzing from the speakers.
            The standby light on the front is also blinking 5 times. According to the service manual these are possible causes -
            • Video OUT (IC561) is faulty. (A Board)
            • IC355 is faulty. (A Board)
            • Screen (G2) is improperly adjusted.**
            This leaves me wondering about the G2 voltage. I had messeed with it a bit and thought I got it set back to where it was. Not sure how precise this needs to be.
            Given there is no high voltage, however, maybe those IC's are not getting voltage either and it's just thinking it's an issue with the video out ICs.
            • cmonkey
              Sony Trinitron KV32FV27 Power Supply Problem
              by cmonkey
              I'm just creating this thread to document this issue so I don't forget what I've tested so far.
              Technical Manual.
              I've measure CN641 on the power supply board ( board G ) and all the voltages are about half of what they should be. So the 9V pins are measuring about 5V, the 135V pins are measuring about 70V.
              I replaced the two large main caps ( C606 and C607 ) and also C643 and C641 with new capacitors without doing any more troubleshooting and strangely the TV worked for about 30 minutes and then started behaving the same way.
              I can't figure...
              03-30-2024, 09:22 AM
            • motorahead
              Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
              by motorahead
              Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
              After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
              10-21-2023, 03:50 PM
            • ptcriserx3
              Sony trinitron crt bowed and side color issues
              by ptcriserx3
              Hi
              Ive got a vintage 2001 sony trinitron flat tube tv
              The image is slightly bowed and the left and right sides about 1-2in has fluctuating discoloration that comes and goes if i move or hit tv on sides
              See many images attached...
              Just windering if this is not fixable or something i can correct without getting too invloved
              Im trying to sell the tv
              06-17-2023, 07:27 PM
            • Carlos#2003%
              Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
              by Carlos#2003%
              Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
              02-15-2024, 07:52 PM
            • sickboy
              Strange CRT Fault (Sony Trinitron M1410U)
              by sickboy
              This is a CRT I sold a few months ago and it's came back with this weird issue. It's intermittent, but not a thermal fault, or tap sensitive - just completely random. The right side of the picture completely blanks out (picture is not shifted). The on screen display is unaffected though, so not a fault in the line section. Anyone seen anything like before in a CRT?
              11-10-2024, 05:02 AM
