Samsung QE65Q60TAUXZT New Mainboard but wrong colours
  • alltvrepairs
    • Jan 2014
    • 219
    • Malta
    I have ordered a new main from Samsung. Tv works fine but colours are wrong. I have updated the Panel type as per panel sticker but made no difference. I have another spare good main board and copied the SPI data to the new board but still same problem.
    I have attached pics to what difference I have found a difference n the Tcon value as per (2). However haven't found from where I can modify this value. Note I have entered SM with normal remote. Currently I do not have Factory remote.
    Do we have a Service Manual for this please?
    Any assistance welcome!
  • lotas
    • Jan 2016
    • 4606
    • Russia
    Re: Samsung QE65Q60TAUXZT New Mainboard but wrong colours
    Throw from the old, native motherboard spi flash 25Q80 T-CON (it stores the settings, permissions of your panel).
    • Diah
      • Feb 2013
      • 6375
      Samsung sell MB as blank always...
      just write the TV Model at SM. then T-CON will married with MB
      • alltvrepairs
        • Jan 2014
        • 219
        • Malta
        Tks both for replying.
        I haven't found where to write the Model I have visited all pages in SM bit couldn't find this option. Do you recall in which Menu I can find it?
        • alltvrepairs
          • Jan 2014
          • 219
          • Malta
          I have swapped the SPI but same problem
          • lotas
            • Jan 2016
            • 4606
            • Russia
            See here how to change the panel.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4333
              • Italy - Milan
              You can try copying the 24c memory hidden somwhere and perform a service reset.. you lack of tv model, mainbboard model is usually stored in that memory, bytes at bottom ..
              • lotas
                • Jan 2016
                • 4606
                • Russia
                This cannot be done! It stores the keys and these keys must match the keys that are stored in the eMMC. Get a cripple from the TV.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4333
                  • Italy - Milan
                  what stores the 24c memory? what happens when you do a service reset?
                  • alltvrepairs
                    • Jan 2014
                    • 219
                    • Malta
                    Thanks @Lotas for the pdf. It contains the information required
                    I need to go into Factory Mode. Appernatly I cannot use my current remote Will try to find a workaround with a universal one.
                    Update later..
                    • lotas
                      • Jan 2016
                      • 4606
                      • Russia
                      It stores settings and unique keys, if it is native 24c512, then factory reset resets the default settings.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4333
                        • Italy - Milan
                        that 24c stores settings is quite obvious, my guess is that it is intended only for device profiling, it is read once the first tv turn on in factory, it initialises two files in the flash, one is the default and one is the actual settings, so my guess is that copying the eprom has no effects but i'm not sure about it, one can try (?), when a factory reset it is made it copies the default file in the actual file.. so no go.. why the keys on the eprom must match those on the emmc?
                        • lotas
                          • Jan 2016
                          • 4606
                          • Russia
                          They have an eeprom + emmc + spi binding, whichever you change to someone else's, the TV will either not turn on or be crippled (not all functions will work.
                          • alltvrepairs
                            • Jan 2014
                            • 219
                            • Malta
                            I have obtained a Factory Remote, Followed the SM and updated the required information as per section 4.8.
                            Unfortunately no improvement at all.
                            Probably will contact supplier of board to see if they may help.
                            Any more thoughts?
                            Tks
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4333
                              • Italy - Milan
                              the type is wrong, must be put 65S6AU0RT
                              • alltvrepairs
                                • Jan 2014
                                • 219
                                • Malta
                                Sorry wrong pic. This is the latest with same pinkish comour symptoms.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4333
                                  • Italy - Milan
                                  maybe something is bad in the mainboard lvds output, check if the balancement resistors are all in place..
                                  • Diah
                                    • Feb 2013
                                    • 6375
                                    did you make factory reset after editing... in case yes.. can you play on it HD test picture jpg format
                                    • lotas
                                      • Jan 2016
                                      • 4606
                                      • Russia
                                      Did you do a factory reset after all the settings?
                                      • alltvrepairs
                                        • Jan 2014
                                        • 219
                                        • Malta
                                        I have factory reset from Factory SM at least 3 times.
                                        I have hooked HDMI inputs and colour difference is in all inputs. I can see a Failure notification in every screen while in SM whicj cannot find from where as HW Test retuned good results.
                                        This is the difference I am seeing in ADC/WB Mode:
                                          09-07-2024, 05:50 AM
                                        • bohaboha
                                          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                          by bohaboha
                                          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                          04-19-2025, 01:47 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
