Lg 55lb6000 lamps replaced -new issue after
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I had a lg 55lb6000 in for no backlight issue.Well i replaced them all as usual and took extra care with panel.When i reassembled all look well until i hooked up the hdmi source,there was slow motion blur on laft side about 1/4 of screen.I initially suspected t-con and had one so that wasn't it.I replaced main board also as i had one,no go.I ended up ripping those 4 tabs of panel and full brightness and screen returned to normal.Anyone else have experience like this?
    • 12331
    • U.S.
    Re: Lg 55lb6000 lamps replaced -new issue after
    Prolly the usual bad cof on that side, did you take a good look at the cofs, a lot of times you can tell a bad one, a hole somewhere, discoloration, black, misshapen.
    • Diah
      • Feb 2013
      • 6608
      lucky you.. i assume you are still in winter cloth ... next time you need to ware earthing band when you are working with electronic.
      • sputnikoff
        • Feb 2016
        • 203
        • canada
        Still winter here 9 of them sited.
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          Still winter here....9 of them sited so far
            • 12331
            • U.S.
            No shit, you got polar bears? I think they're AWESOME but I would give them a very wide berth and not get on their property.
            • sputnikoff
              • Feb 2016
              • 203
              • canada
              Ya ice in Labrador straits got blocked up seals everywhere and their friends polar bears lol.
              • Diah
                • Feb 2013
                • 6608
                cool.... no need TV at all... you are in live program National Geography Wild
                • bart64
                  ASUS M5A99FX Po Motherboard DIMM Issue , DIMM led keeps flashing after defective DIMM replaced.
                  by bart64
                  After my ASUS motherboard had random freezes and lockups, i found out that a defective dimm caused the issue, but after change the red indication led on the board keeps flashin with new dimm memory . Reset of the pushbuttion or reset of the cmos does nothing. After the damage one FET near the dimm gets very hot and also some smoke appeared of probably small smd resistors or ic probably. After replacement the FET still takes to much power and burns. When the regulator/ power ic close to the dimms UP1642P is removed the fet keeps cool so I decided to order this and replace it with a new one. But...
                  10-18-2025, 05:51 AM
                • bcstedt
                  LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
                  by bcstedt
                  LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
                  Problem:
                  On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
                  It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
                  01-18-2024, 01:03 PM
                • ugamazing
                  by ugamazing
                  12-17-2024, 07:05 PM
                • ahmarzo
                  Acer laptop battery draining issue
                  by ahmarzo
                  Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                  Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                  08-02-2025, 06:39 AM
                • elmark
                  HP 15-cw1002ua strange keyboard issue
                  by elmark
                  HP Pavilion 15-CW1002UA
                  S/N 5CD0251CBC
                  P/N 7KE54EA
                  Hello guys!
                  I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                  It powers on OK and has no other issues except the following:
                  • CAPS LOCK does not work at all
                  • Fn button toggles Flight Mode
                  • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                  • (with SHIFT pressed: 't%' and 'y^' respectively)
                  I initially thought it was a keyboard malfunction (internal short, etc.),
                  but when I press and hold...
                  06-27-2025, 01:10 AM
