Samsung LE32S81B - missing standby voltage
  • Sportline
    • Jan 2023
    • 9
    • Bosna i Hercegovina
    Good day, instead of Q0165R I mistakenly put 24C256 (don't ask me how) and made a short circuit. After I put Q0165R I don't have stand by voltage again. There is no voltage on the cold side. I found the schematic.
    I checked a few things but didn't find anything. When I checked the DB802 diode, it showed a short circuit, but when I unsoldered one leg, it looked fine, and I still have a short circuit on its contacts. On the other side of the board, I have DZB801 also shorted, but it is SOT23, so I didn't remove it, do you think it could be connected to it? Could there be some protection in this marked transformer, how to check it? Or do you think that the ISM801(MC33067) is damaged, how can I check it (I don't have an oscilloscope), I looked at VCC to ground, it is not short circuited, but I have a small voltage on VCC, and the datasheet says 20V??? Is it the voltage after the TV is turned on?
    Any help is welcome.
  • Sportline
    • Jan 2023
    • 9
    Re: Samsung LE32S81B - missing standby voltage
    I found a short circuit (marked in red on the diagram) it is DZB801 30Vz SOT23
    After I connected the voltage to the board, I got stand by voltage.
    I'm wondering if that diode is there only in terms of protection, will it work without it?
    Ako je trebam zamjeniti kako da nađem oznaku?
    • R_J
      • 9561
      The zener diode is required to regulate that voltage to not go above 30v, if it does the ic will be damaged. You should also replace that electrolytic CB802 (22µf/50v) next to it, they dry out over time.
      • Sportline
        • Jan 2023
        • 9
        I'm bad with labeling these things, if you can help me, I took a better photo?
        • R_J
          • 9561
          It seems to be a 18v zener, BZX84-C18 or Z02w18vy, Looking at the correct schematic, DZB801 is a 18v zener not a 30v zener
          FSQ0165RN maximum VCC voltage = 20vdc
          • lotas
            • Jan 2016
            • 4668
            • Russia
            Yes, "Y6" - BZX84C18-V (18v).
            • Sportline
              • Jan 2023
              • 9
              I finally got the diode, replaced it and the TV works, satisfied.
              But my main problem that caused me to disassemble the TV is still there. When it turns on, it is amplified to max. more precisely at 300 and when you go to reduce the volume, a line remains on the screen as seen in the photo.
              In addition, I also replaced all capacitors, one was bad.
              Has anyone had a similar problem?
              • lotas
                • Jan 2016
                • 4668
                • Russia
                I don’t understand, when you turn on the TV, the volume is automatically increased to the maximum and when it is reduced, it again starts to increase to the maximum?
                • Sportline
                  • Jan 2023
                  • 9
                  Yes, the volume is more than 300 and when you go to reduce it to 301 it is like 1 and when you go to 299 it is again at max then at 201 it is like 1 at 199 it is again max and so on until you reach the normal scale 1-100 but this trace remains on the screen and is not deleted.
                  • lotas
                    • Jan 2016
                    • 4668
                    • Russia
                    Try unplugging the keyboard from the motherboard and test with the remote.
                    • Sportline
                      • Jan 2023
                      • 9
                      Tried, same story.
                      • lotas
                        • Jan 2016
                        • 4668
                        • Russia
                        Try to put a clean eeprom 24c256.
                        • Sportline
                          • Jan 2023
                          • 9
                          That was my first plan, if you read my first entry it will be clear to you. But apparently I was stupid and went to look for the eeprom on the power board instead of the main one. It's my school and it looks like I had the wrong version, mine was with legs, and that's where the smd version goes.
                          • lotas
                            • Jan 2016
                            • 4668
                            • Russia
                            You can unsolder it (25c256) from the board, save the data (dump) just in case, then erase it (so that all FF is in it) and solder it back.
                            But for this you need a programmer.
                            • Sportline
                              • Jan 2023
                              • 9
                              Ok, thanks for the tip, I'll give it a try.
                              • tvguy12012012120
                                by tvguy12012012120
                                02-07-2025, 05:13 PM
                              • x_orange90_x
                                Samsung UN55KU6300F no standby voltage
                                by x_orange90_x
                                I have no standby indicator light and no light on the optical port. I checked the standby voltage on the two mosfets in the top left and they both read 30mV. I checked the fuse and it has continuity. I also checked the voltage on the two large 450v caps they both read 153v. All of these voltages are the same with and without the main board connected as well as with backlights connected/disconnected.
                                Nothing looks obvious like a burned ceramic disc cap or bulged electrolytic. No burned resistors, diodes, or anything like that....
                                05-21-2025, 09:59 PM
                              • platinumsteel
                                HP 14-dq2088wm 11th Gen Missing 3V/5V Standby Voltage
                                by platinumsteel
                                Hi guys have a HP 14 Labtop. DA0PAHMB8F0 .There is no White LED on the DC Jack .It got a drop of water damage right next to the 3V IC ( Silergy SY8386BRHC) and corroded a resistor and a pad which belongs to the Enable for the IC. I cleaned the area and re-soldered the resistor. Nothing Changed. I don't know what the value for the resistor should be.It measures about 80.0K No schematics available for this model. A good friend on here mon2 helped me identify the IC markings and gave good advice on making sure to measure the input voltages and enables and checking for short.
                                There is no short...
                                11-12-2024, 05:49 AM
                                09-07-2024, 05:50 AM
                              • EdwardGeo
                                Lenovo 700-15ISK-80RU - Standby voltage missing
                                by EdwardGeo
                                In Short: the laptop was flooded with water 3-4 years ago, but after service cleaning was working fine, except battery wont charge on it. After years, a month ago, laptop just shutdown itself and never power on.
                                After first board review, the short circuit was found. The capacitor died and burned pad. The temperature was so high that the two layers of textolite were burned. Good news that the layers was GND, so nothing critical. The burned fragment was cleaned and the short gone. Replaced them, but no standby voltage. When...
                                09-03-2021, 05:28 AM
