Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Do you use it through a clamp or do you unsolder the flash and use an adapter on the programmer?
    Try another flash...
  • yureyko
    replied
    I was experimenting with everything back then... Now all the settings are correct.
  • lotas
    replied
    Originally posted by yureyko
    I tried your firmware, but I have the same problem. I have a black CH341A.
    When I try your other firmware for different TV models, I still have the same problem. It's probably an issue with the programmer or the SPI chip.
    And in the settings it is set as green.
  • yureyko
    replied
    Originally posted by lotas
    Try this dump.
    And is your CH341A black or green?
  • yureyko
    replied
    Try to remove protection first, i.e. remove all checkboxes and press "Write", then erase and write dump again, then set the status register again...
    The same behavior in three programs (SiberiaProg, Colibri, NeoProgrammer).
  • lotas
    replied
    Try this dump.
  • yureyko
    replied
    The same result, it immediately enables that parameter.
  • lotas
    replied
  • yureyko
    replied
    Maybe I have a problem with the SPI chip or the CH314A programmer. Mine is not modified. Do I necessarily need to modify it?
  • yureyko
    replied
    There should be only (S3, S7, S9, S14).
    Try to record your native dump again via NeoProgrammer_2.2.0.10.
    In the program:
    1. Click "Detect Chip" and select W25Q40CL and "Select IC".
    2. Click "Unprotect".
    3. Click "Clear IC" and "Yes".
    4. Click "Open File" and select your corrected dump.
    5. Press "Program IC" and "Yes".
    6. Click "Verify IC".
    7. Press the down arrow to the right of "Unprotect" and select "SREG Edit", put a check mark on SRP0, BP1, CMP, QE (S3, S7, S9, S14) and press "Write" and "Yes"
    7. Close the program. Ready.
    Dear lotas ,​
    I already have some default parameter set. That's why I can't set the register code 0x42.
  • lotas
    replied
    In the program:
    7. Close the program. Ready.​
  • yureyko
    replied
    Then check what status register is set, maybe it has crashed (it should be 0x88, 0x42).
    Dear lotas ,
    After installation in the TV, the status changed to 0x46.
  • yureyko
    replied
  • lotas
    replied
    Interesting...
    All voltages are present, but the indicator does not light up.
    However, when I try to flash the SPI with a working firmware from a similar model, the indicator lights up, but there is no startup...​
  • yureyko
    replied
    Your dump is working, the problem is different...
    Interesting...
    replied
    The thread title has been renamed to Samsung "MU" series (UN, UA, UExxMUxxxx) fault dump IC1604 25Q40...
  • lotas
    replied
    Greetings friends,
    i have a Samsung TV UE40MU6402U with board BN41-02568b
    The problem is that i have no standby
    I thint that maybe the problem is software related since i have voltages in board.
    I read the IC1604 (W25Q40CL)
    Propably problem is the IC1604 but i read all of them.
    If someone knows or have software to help please you are welcome.
    Thanks in advance for your time and your help.​
  • yureyko
    replied
    Greetings friends,
  • lotas
    replied
    Originally posted by ducky29
    Thanks Iotas. It works fine!
    Ok!
  • ducky29
    replied
    Hi, try the working dump.
  • Yanleb
    UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
    by Yanleb
    My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
    Disconnecting the main board from the power supply makes the backlight come ON.
    I did disconnect the panel cables and the WIFI modules, the board is still dead.
    I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
    Thanks.
    11-18-2024, 12:34 AM
  • ogabuga
    Asrock B650E PG-ITX BIOS_WHP1 /25Q40/
    by ogabuga
    Hello, I need a dump of the BIOS_WHP1 /25Q40/, EC controller chip /NTC6686D/. The motherboard is coming for repair after a another service, what is in the dump that I downloaded is the beginning of the MAIN BIOS, according to the analysis that I did based on the documentation of the EC controller NTC6686D, the content should be different. BIOS_WHP1 /25Q40/ is connected directly to SCE1#, SO1, SI1, SCK1 pins 66, 68, 67, 69 of the NTC6686D​
    01-28-2025, 04:48 AM
  • daniel0799
    Full 25Q40 dump for TP-LINK TL-SG1016D V7 (RTL8382L + 2x RTL8218B, PCB KB616010558)
    by daniel0799
    I’m looking for the **full 512KB (25Q40) SPI dump** for **TP-LINK TL-SG1016D V7 (unmanaged)**, PCB code **KB616010558**, with SoC **RTL8382L + 2×RTL8218B**.
    My current dump only initializes 8 ports and the LEDs are misaligned, so I believe I have a firmware from an 8-port model.
    I need a complete dump (bootloader + firmware) from a working switch to restore full 16-port operation.
    If anyone has this model or a similar V7 revision, please share the BIN file or point me to a resource.
    I can provide photos of my board and the flash...
    10-22-2025, 11:12 AM
  • alro7779
    Samsung UN55MU6103F video problem; has colored stripes on the display
    by alro7779
    Hello, everyone!
    A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
    09-27-2025, 11:29 PM
  • totof
    Samsung UE55MU6102K IC1604 dump needed - TV don't start
    by totof
    Could you help me...
    I have a Samsung UE55MU6102K with the following problem : I disconnect the motherboard from main power supply from and the backlight leds light up.
    Then motherboard connected, standby led is on and current consuption is 18W.
    Then trying to start the TV, the standby led is blinking once but TV don't start and standby led stay red.
    Maybe the firmware in the IC SPI Flash W25Q40CL (IC1604) is corrupted.
    The model of my TV is :
    Power supply BN44-00807A
    Main Board BN41-02568B / BN94-12765W
    Panel CY-GM055HGLV3H...
    05-01-2023, 04:30 AM
