Need Help Identifying Component For Printer Main Logic Board HP M570DN
  • grimacelord
    • Jan 2017
    • 363
    Hello. I know that I am asking for help with a printer, but this is specific to the printer's logic board so I figured it would be best suited under the motherboard repair forum - please move if better suited somewhere else.
    I have an HP M570DN printer that has stopped being recognized by USB. This apparently happened after a lightning strike. I pulled the logic board out of the printer and did a visual inspection of the board under a microscope. Board looks ok. Then I started checking random caps looking for a shorted line somewhere. I eventually discover one. I inject 1V into the line and look under thermal camera and find a component just behind the USB port that is getting hot. This component is 6 pins and labeled "NFTF".
    I did some Google searching and I did find some images of it, but the websites where those images are located on don't describe what it is. Here is the site I found that had it: https://www.indiamart.com/proddetail...732612462.html
    It's sort of vague and just says it's made by Texas Instruments, but I am not even sure of that's true.
    I was hoping someone could help me identify this component so I could replace it and see if it restores USB connectivity rather than having to replace the entire logic board.
    Thanks. Pics attached.
    • 20645
    Re: Need Help Identifying Component For Printer Main Logic Board HP M570DN
    It is a TI part.
    https://www.ti.com/packaging/docs/partlookup.tsp Entered the first 3 digits then googled TPD2S017
    https://www.ti.com/product/TPD2S017
    https://www.aliexpress.com/wholesale...t=tpd2s017dbvr
    • grimacelord
      • Jan 2017
      • 363
      Originally posted by SMDFlea
      Awesome. Thanks!
      • Dani_2024
        by Dani_2024
        10-28-2024, 05:06 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
      • JDC
        by JDC
        ONN 100012588
        Long answer:
        07-15-2022, 07:39 AM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • cheeky2
        by cheeky2
        05-25-2024, 03:27 AM
