Samsung Xpress C1860FW something smells overheated
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I'm no expert on printers. I have this colour laser here, it has new toner cartridges fitted - Samsung Xpress C1860FW
    It power on but after a minute it starts to smell bad like something is getting very hot (but not smoke). It's not so much a burning smell it's more acrid like burnt TCP or something similar
    It's hard to pin down exactly where the smell is coming from but there is a gap under the scanner and in the back are some rollers - if I put my hand down there it feels warm. This is where I tried to take a photo (see attached)
    The client says it does try to print but the paper jams in the back
    Any suggestions what could be the problem with this one?
    Follow me on YouTube
    Learn Electronics Repair
  • R_J
    • 9604
    Re: Samsung Xpress C1860FW something smells overheated
    What is getting hot and what you smell is likely the fuser roller heating up.
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      OK R__J
      I will have to bring some paper to the workshop tomorrow and try it
      It smells nasty though, what would cause that? Coud it just need cleaning? I've smelt something similar before when LCD inverters fail - but then of course there is a lot of smoke
      • R_J
        • 9604
        Well there is the fuser roller that gets hot and if there was dust built up on it from sitting and not being used for a long time that might smell for a while. There is also a high voltage power supply that might cause an ozone type smell.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Thanks R__J
          I decided to ignore the smell and install the drivers (USB). When I turned on the printer the status LED went read and gave an error #U1-2320 - which means Fuser Unit failed (apparently)
          I googled that and it said turn off and on again. I did that and this time I got no error - Status LED Green
          I installed the drivers, then decided to try the copy function on the printer
          The first page (excel spreadsheet) copied but the quality is shite
          The next page I tried is a colour document, it scanned and copied in monochrome (could just be some setting) and again the quality was rubbish, then the page jammed and the printer said 'Output paper jam'. It jammed coming out of the fuser unit. I managed to pull it put gently.
          I then removed the fuser unit, this is definitely where the strong smell is coming from. It looks all grubby on the roller.
          So between the error code, your advice and the paper jamming coming out of the fuser, everything seems to be pointing to this being the faulty item.
          Should I clean/service it or replace it?
          Ahh NO. It's got paper all wrapped around it!
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            OK I removed all the brittle paper from the roller and it's working good now
              • 31246
              maybe someone tried to print on some shit that had a coating.
              like plasticised paper or a big sticker-sheet
              • CapLeaker
                Leaking Member
                • 8339
                a piece of shit with a coating?
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
