Can0n PIXMA PRO 100
  • HS13
    • Feb 2014
    • 17
    Can0n PIXMA PRO 100
    Does anyone know how to fix the logic board there are no WIFI on. LAN error not found. before that's happed, the USB port center is broken I didn't see and I plugin the PIN inside the port get Short After that no WIFI. LAN or USB to connect to my computer.
    Thanks for HELP.
  • DumpCraft
    • Jun 2025
    • 16
    • Ukraine
    Thanks for HELP.
    try using Canon Service Tool
    hardware id?
    • HS13
      • Feb 2014
      • 17
      Thanks for helping me. will try later.
      • HS13
        • Feb 2014
        • 17
        Component identification code SMD Zener and the Transistor (Canon printer Pro 100)
        on board ZDA901 the letter on chip (C U) and the other Q1201 the letter on chip (ULR 25)
        Thanks for your Help.
        • Shplad
          • Jun 2024
          • 4
          hardware id?
          How do I download this in Windows without it triggering a virus warning. It won't allow download.
          • DumpCraft
            • Jun 2025
            • 16
            • Ukraine
            use a different browser such as one that allows you to confirm the download.
            The antivirus will cuss anyway
            • HS13
              • Feb 2014
              • 17
              Thanks, Dumpcraft
              I did try the windows delete.
              • Shplad
                • Jun 2024
                • 4
                Thanks, Dumpcraft
                You have to disable real-time protection and cloud protection in Defender before downloading it.
                • HS13
                  • Feb 2014
                  • 17
                  Hi, Shplad.
                  Now what do I do? How I have the key?
                  • chth96
                    Is it possible bridging tiny broken trace
                    by chth96
                    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                    cutting tiny trace.
                    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                    12-03-2022, 11:32 PM
                  • korben_dallas
                    Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                    by korben_dallas
                    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                    MY QUESTION:
                    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                    02-14-2024, 12:23 AM
                  • Yanleb
                    LG 60PK550 Logic Control Board EBR63450301
                    by Yanleb
                    Hi all, I just want to share the repair of my 60PK550-UA TV set.
                    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
                    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
                    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
                    C57: 3.30V
                    C61:...
                    07-20-2023, 12:38 AM
                  • mferna14
                    Logic Board 820-00840-A Missing EDP_BKLT_EN
                    by mferna14
                    Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                    07-10-2024, 05:18 PM
                  • mferna14
                    Logic Board 820-01987-A missing PP3V3_S5
                    by mferna14
                    Hi good Friends., today working on a Macbook Pro A2289, Logic board 820-01978-A. The history was liquid spill, Cleaned & replaced all corroded components & now the logic board shows 20v & .01amp on the meter. Not taking in any amps. Upon trouble shooting I get the required stable voltages 5V, PP3V3_G3H 3.3V but no PP3V3_S5. Checked the schematic, assume that this is generated from U7800. Checked all the Input/Output voltages on this chip. All is fine, except PP3V3_S5 is missing. Resistance from GND to PP3V3_S5 is 146 Kohms. First I need to make sure whether PP3V3_S5 is generated from...
                    06-07-2025, 05:07 PM
