i need dump file pls
Epson L18050 need dump file
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by KoleckiHi I need bios or firmware dump file to printer Epson et-2756. Can you help me. My printer is bricked in printer mode and i need reprogram chip on board01-18-2025, 11:38 AM
by String2016I need a working dump file for EPSON L3250 please
by kenzo2I need dump file for nand A2159 512GB with 2 Nand chips >.I upgraded 128gb to 512gb..I use P13 there are only 4Chips...
I need dump file MACBOOK PRO A2159
TSB4232(256)
TSB4229(256)
Thanks​ -
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
- Loading...
