I need a working dump file for EPSON L3250 please
Epson L3250 dump file
Tags: None
this one is working already tried.Attached FilesPremium supporters get full download access and other benefits.
L3250_eeprom.BIN, please try this file.Attached FilesPremium supporters get full download access and other benefits.
L5190Attached FilesPremium supporters get full download access and other benefits.
by weisianHi all,
I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...-
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by KoleckiHi I need bios or firmware dump file to printer Epson et-2756. Can you help me. My printer is bricked in printer mode and i need reprogram chip on board01-18-2025, 11:38 AM
by theaarononeI have had this beast in pieces for days going through everything bit by bit - I finally got a chip to read off the main board and it has a high blank / ff count, so I'm wondering if anyone out there has this monitor in working condition that could provide a working firmware?
- Board number: BN41-03169A
- Monitor: Samsung Neo G9 57" LS57CG952NNXZA
- Symptom: No power, FPGA DONE/ALIVE at 0V
- Flash chip: Winbond W25Q128.V
- I've got a dump showing 74% erased/0xFF
- Requesting a good firmware dump from anyone with a working unit
04-23-2026, 08:37 PM - Loading...
