Oki B6300 SMD Capacitors for Network port
  • Jeff Schmidt
    • Jan 2024
    I have had a few power hits and notices that network isn't working to printer, settings still set for static IP, get link LED on switch but no ping. Removed board "PWB Walther2 140E49380" and measured all (3) large caps (C2619, C2620, C2621) in picture with Diode Mode on Fluke, ESR meter, and continuity mode with reversing the probes, no readings for any. What value SMD capacitors would these be?Click image for larger version
Name:	B6300 Board.jpg
  • harp
    • Jun 2022
    • 615
    • Planet Earth
    For cap value look in datasheet of this transformer and check if it is ok.
    • fredyjbi
      please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
      by fredyjbi
      I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
      if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
      I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
      if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
      On the type...
      07-09-2024, 11:28 PM
    • dragon3x
      by dragon3x
      power on.
      Here are some examples :
      switching supply area).
      than 6.3 V.)
      03-21-2025, 02:46 PM
    • howardc64
      Samsung UN55JU650DF network/streaming problem
      by howardc64
      Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
      This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
      07-09-2025, 12:44 PM
    • davg
      Home network connection problem
      by davg
      I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
      03-06-2021, 07:13 AM
    • slybunda
      AA and AAA battery charger capacitors?
      by slybunda
      hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
      it has inside:
      2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
      2 x 470uf 16v LZ105c branded as G.Luxon
      not heard of these brands are they any good?
      iv attached photos of the charger and the board inside for an idea on the type of...
      12-24-2023, 04:41 AM
