HP 8000 series power supply Fan spins and stops
  • NConstantinou
    • May 2017
    • 334
    • Cyprus
    Hi all
    i have an HP power supply PS-4321 connected in series with bulb.
    Series lamp is blinking when i short green wire and ground.
    Voltage on mail capacitor is fluctuating.
    i changed all capacitor but still the same.
    i checked for short NO SHORT.
    i looks like power supply is restarting that is why series lamp is flashing.
    without power i do get correct voltage on main capacitor NO FLUCTUATION but i am missing 6v on a smd capacitor that is connected directly on ic 6802.
    i also changed ic 6802.
    there are 3 optocoupler and the middle one on high side i should get 17v but i get a little voltage.
    on secondary side i do have the 5v and aux 12v.
    if i disconnect the side side of middle optocoupler and install diode, negative to ground the series light bulb is not flashing and voltage on mail capacitor is ok
    can someone help!
    by sam_sam_sam
    03-31-2024, 02:12 PM
    by sam_sam_sam
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • CMCM
    Russound CA4 Power Supply Repair
    by CMCM
    Hello Everybody,
    Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
    Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
    The outputs marked 12v and 20v are all measuring only 1v.
    The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
    The capacitors physically look clean (no bludgesor leaks) and...
    07-03-2025, 01:12 PM
