HP 8000 series power supply Fan spins and stops
  • NConstantinou
    • May 2017
    • 354
    • Cyprus
    Hi all
    i have an HP power supply PS-4321 connected in series with bulb.
    Series lamp is blinking when i short green wire and ground.
    Voltage on mail capacitor is fluctuating.
    i changed all capacitor but still the same.
    i checked for short NO SHORT.
    i looks like power supply is restarting that is why series lamp is flashing.
    without power i do get correct voltage on main capacitor NO FLUCTUATION but i am missing 6v on a smd capacitor that is connected directly on ic 6802.
    i also changed ic 6802.
    there are 3 optocoupler and the middle one on high side i should get 17v but i get a little voltage.
    on secondary side i do have the 5v and aux 12v.
    if i disconnect the side side of middle optocoupler and install diode, negative to ground the series light bulb is not flashing and voltage on mail capacitor is ok
    can someone help!
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
