PS4 pro PSU ADP-300CR shuts down when turning on 12V
  • JonnyS
    • Apr 2016
    • 9
    • Poland
    I would like to ask for your help to troubleshoot a faulty PS4 pro power supply
    I have a st_by voltage ane when i try to power on 12v line PSU shuts off
    i measure lot of components but i don't fins faulty piece ,
    when i try to power on 12v line voltage increasing to ~420v so it looks like PFC was working,
    Now i have no idea what i can do more to fix it and i will be very helpfully to help me in this case.
    • Jul 2011
    • 6040
    Re: PS4 pro PSU ADP-300CR shuts down when turning on 12V
    Need some pictures of the circuit boards in this device
    • lotas
      • Jan 2016
      • 4618
      • Russia
      Rather, the problem is in the set-top box itself, if you manually start it and 12 v appear, if there is a problem with the set-top box, then it blocks these 12v.
      • JonnyS
        • Apr 2016
        • 9
        • Poland
        am sending the board photos
        • JonnyS
          • Apr 2016
          • 9
          • Poland
          any ideas ?
          • Norrecito
            PS4 pro PSU (ADP-300FR) shuts down when turning on 12V
            by Norrecito
            Hello all,
            I would like to ask for your help to troubleshoot a faulty PS4 pro power supply (ADP-300FR).
            A couple of weeks ago, I've picked up a PS4 Pro (CUH-7216B) from one of the local flee markets. According to the seller, it has a "no power" issue and the PSU is most likely faulty. Based on the cracks on the housing, it was probably dropped.
            Tried it at home and sure enough, it had a "no power" issue. (Pressing either the power or eject buttons had no effect).
            I took out the PSU and opened it. Immediately noticed...
            08-20-2022, 10:26 AM
          • huzo
            HP Omen shuts down when loading OS
            by huzo
            The model is 15ec-1061nm
            Board number is DAG3EDMB8D0​
            SO i turn the laptop on , and as soon as it starts booting from disk, from usb, windows,linux,HBCD,anything i boot it just turns off....while in bios menu or in linux boot menu it stays on normally...It's like when it starts to use graphics it shuts down...But i measured 0.72V while working on the GPU power line,no excess heat is comming from GPU or CPU, i even removed the heatsink and turned the laptop on and everything worked fine, got a bit hot, fan span to full speed, but it worked like that for few minutes in bios...
            10-29-2024, 12:05 AM
          • baglaivlad
            A1706 820-00239 - Works, but sometimes shuts off when the charger is disconnected
            by baglaivlad
            Hello everybody!
            Have in work A1706 820-00239 model. Originally no power, shorted PPBUS_G3H because of corroded C6403, C6404. Some water damage around this components, but nothing major.
            After replacing this capacitors the laptop came back to work, I reinstalled MacOS and had no issues until I started to test Type-C ports. Sometimes the laptop shuts off immediately when some action with Type-C ports performed (charger disconnected or USB device inserted/disconnected). I checked Type-C port flexes, they are okay, but I cleaned them anyway. I can't see any signs of liquid...
            11-20-2024, 08:14 AM
          • samuelphirik
            Dell inspiron 15 7567 sudden shuts down
            by samuelphirik
            Hi. I have a pre-owned Dell Inspiron 15 7567. It worked fine
            During the first 3 days of owning it until Dell Update software popped a notification about a latest Bios version 1.15.0 and latest Intel ME Software update of which I updated. It rebooted and firstly, Upgraded Bios from version 1.8.1 to 1.15.0 then it started upgrading Intel ME firmware. After that update, my laptop shuts down without notice (Like thermal shutdown)
            I checked Thermal Paste on the processor and the Graphics Chip and it was dry. Replacing thermal paste has not helped me.
            Now I've noticed that laptop...
            07-02-2023, 05:45 AM
          • Sparklingx
            HP 450 g1 keeps turning on even tho shutdown/sleep
            by Sparklingx
            HP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
            09-23-2024, 12:34 AM
