problem with Delta GPS750AB A PSU. No +5v VSB
  • smile
    ICC ProfileGuru
    • Feb 2013
    • 120
    • Lithuania
    Re: problem with Delta GPS750AB A PSU. No +5v VSB
    TNY280PN datasheet:
    https://cdn.badcaps-static.com/pdfs/...953d6e2eb9.pdf
    R1 was 4.33K +5vsb unstable
    replaced with 1K 5V stable, but when soldered back supervisor IC and other smaller board, instantly burned.
    It's hard to tell what original resistor was as it overheated (was coated all in resin) the color code read as 4.33K
    • smile
      ICC ProfileGuru
      • Feb 2013
      • 120
      • Lithuania
      Instead of 1K, I put 1.5K now it burns when starting the PSU with green+black wires shorted.
      The PK6E200A diode measures as good, one way O.L the other way 0.516V
      The other small one D5 measures only one way. so it's good.
      • smile
        ICC ProfileGuru
        • Feb 2013
        • 120
        • Lithuania
        PK6E200A diode is a TVS diode Working Voltage: 171 V
        These can't be tested with DMM right?
        https://eu.mouser.com/ProductDetail/...FymH4LMw%3D%3D
        • CapLeaker
          Leaking Member
          • 8352
          as long it isn't shorted, it's good. Those are TVS diodes and yours can't be bad. However, maybe you did misread the resistor...
          Take that supervisor IC back out and see if any pins are shorted to GND? Maybe take a lab PSU and give the supervisor IC power and see if it draws excessive current or something.
          • smile
            ICC ProfileGuru
            • Feb 2013
            • 120
            • Lithuania
            Nothing else except the resistor that burns get hot. This is after few minutes being off.
            • smile
              ICC ProfileGuru
              • Feb 2013
              • 120
              • Lithuania
              #26
              supervisor IC Dwa108-A same as TPS5510
              https://www.eevblog.com/forum/repair...that-dwa108-a/
              Draws 1mA on VCC pin (the VCC is 16V so how can it be related to +5vsb???), 16ma on 3.3pin 38mA on +5Vpin
              Why it does not draw any power 1mA on VCC??? damaged?
              • smile
                ICC ProfileGuru
                • Feb 2013
                • 120
                • Lithuania
                #27
                I take that back, supply current is specified as 1mA in datasheet. So it's working OK.
                The voltage is same as +5vsb. But the resistor gets burned.
                  • Jul 2011
                  • 6070
                  Either one of two things are issue
                  One you do not have the right wattage resistor or you have a short or something is wrong with current on that resistor ( or you have the wrong resistance value ) or you have to much current draw on that power supply rail
                  • smile
                    ICC ProfileGuru
                    • Feb 2013
                    • 120
                    • Lithuania
                    #29
                    400C with removed supervisor IC, so the problem is with ???
                    With 4.33K +5vsb unstable so that's why it does not burn? When there is 5V stable the rapid heating starts and resistor blows, but who could be using the current.
                    • smile
                      ICC ProfileGuru
                      • Feb 2013
                      • 120
                      • Lithuania
                      #30
                      This video shows same chip problem fix
                      https://www.youtube.com/watch?v=vGS6Y8Z9dAM&t=1259s
                      The author also mentions the resistor going bad and replaces it.
                      However the resistor is 2Ohm !!!!
                      The author shows same datasheet and same diagram for TNY280PN.
                      As you know on diagram there is no 2Ohm resistor but 1K
                      • CapLeaker
                        Leaking Member
                        • 8352
                        I did check a few power supplies schematics and I even saw this resistor value down to 10 Ohms.
                        • R_J
                          • 9633
                          I found this schematic that suggests a 1KΩ It may be that the tvs diode is bad.
                          • smile
                            ICC ProfileGuru
                            • Feb 2013
                            • 120
                            • Lithuania
                            #33
                            So multimeter can't test 100% TVS diode, I need to get new one to test?
                            Multimeter measures only one way, so I would say it is OK
                            • CapLeaker
                              Leaking Member
                              • 8352
                              Your TVS diode should read like a regular diode. One end OL which it did and the other way around with a voltage drop of something like 0.6V - 0.7V, which it did too. You could test it with a bench psu that has CC / CV, but again I don’t think that diode is the problem.
                              While checking schematics for my troubled PSU I did check for the resistor in yours. I came up anything between 10 and 1k Ohms as a value. Others have no resistor in between the diodes.
                              • smile
                                ICC ProfileGuru
                                • Feb 2013
                                • 120
                                • Lithuania
                                #35
                                So the guy putting 2Ohm resistor in video then? 2Ohm is basically short circuit compared to 1K.
                                Should I just replace the resistor with a wire and see what burns next?
                                Should I remove resistor and inject some voltage to see what get hot?
                                • smile
                                  ICC ProfileGuru
                                  • Feb 2013
                                  • 120
                                  • Lithuania
                                  #36
                                  OK,
                                  1. I replaced TNY chip with another one.
                                  2. Replaced TVS diode
                                  3. added a 2Ohm resistor (two 1Ohm resistors in series). Tried 1K but it burned.
                                  Now the PSU does not burn the resistor and starts fine. I tested it with 50W light bulb. So the datasheet is wrong about resistor value !!!!!!
                                  Another problem:
                                  There is chirping sound from PSU once every second when I start it with NO LOAD.
                                  Unstarted it is silent and stable 5VSB output.
                                  If I connect 50W lamp, the sound gets faster every half secod.
                                  You can hear it with load attached in file.
                                  • R_J
                                    • 9633
                                    The tvs diode is a zener diode, how can you tell using a multimeter, what it is zenering at? 100v? 130v? 200v?
                                    • CapLeaker
                                      Leaking Member
                                      • 8352
                                      No wire. I think they use the resistor as a fuse. Also maybe try 10 ohms.
                                      OK,
                                      Another problem:
                                      A chirping of the PSU is usually a shorted voltage rail. PSU tries to start and shuts down. Do some measurements on the high voltage main filter cap and all output rails. See if a voltage rail is missing.
                                      • CapLeaker
                                        Leaking Member
                                        • 8352
                                        Somewhere between 150v and 200v is my guess.
                                        • R_J
                                          • 9633
                                          What I am saying is you cannot determine the zenering voltage of the tvs diode with a meter. It can check ok but what if it is supposed to zener at 180v but is conducting at, lets say 100v it would blow the resistor in series with it.
                                            MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                            This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 03:40 AM
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • Junkrepair
                                            Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                            by Junkrepair
                                            I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                            I found this nice little description of the conversion:
                                            Calculating capacitor ESR from Tan(delta)
                                            https://forum.digikey.com/t/calculat...-from-tan/2633
                                            It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                            06-12-2023, 02:45 PM
                                          • Dynamite76
                                            Dell D635EF DELTA DPS-635AB PSU with blown TNY280PN
                                            by Dynamite76
                                            Recently I got a DELL PSU from a presision T3600. It is a 635W PSU which went out with a bang and some black smoke. The model of the PSU is a D635EF made by DELTA.
                                            The cause of the bang was a blown. TNY280PN Chip. How ever as a result or as a causo also two SMD resistors are smoked. I have been able to replace the TNY280 Chip but I do not know the values of the resistors. The resistors are within the Drain line of the TNY. I can not find the schematic of this PSU. THe resistor are Open Loop and on the voltage accross them is about 330V. (EU)
                                            Any suggestions for...
                                            07-27-2023, 01:52 PM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
