HP Zbook AC adapter 0V at output
  • denem271
    • Feb 2022
    • MEXICO
    Hi, i am facing with an ac adapter that has no voltage output, the main voltage supply is 120 VAC, the center pin of the cord seems bent, is there a way to get a schematic diagram or more information on how to diagnose TEA1716T ic?
    • 31214
    Re: HP Zbook AC adapter 0V at output
    before you do that - check the cable for open wires or shorts - it's common on laptop psu's
    then get the datasheet for the chip - they often have example circuits in them that almost match the board!!
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      https://cdn.badcaps-static.com/pdfs/...f06b063bd3.pdf
      PeteS in CA
      • jayjr1105
        • 281
        Remember, center pin on those is usually a sense wire and not + or -. The inner part of the barrel is usually the + .
        Ryzen 3600x
        16GB Patriot 3600MHz
        MSI B450 Gaming Plus
        MSI Air Boost Vega 56
        Acer 32" 1440P Freesync
        Rosewill Capstone 750W
        Hakko FX-888D Station
        FX-8802 Iron
        MG Chem .8mm 63/37 RA 2.2%
          master hoarder
          • May 2008
          • 12175
          Also, if you saw any damage to the cord, there's a good chance wires in it could be either shorted or open-circuited. So I suggest opening the adapter and unsoldering the output cord, then see if the adapter turns On. Most of the time, I've seen the (+) conductor short to the (-) conductor, especially if the output cord uses coaxial-type construction (i.e. where the signal conductor has an insulation layer on top of it, followed by the + conductor and another insulation layer on top of it, followed by ground and finally the cord's insulation). I have also seen wires open, though - typically near the laptop plug's end. Then the adapter seems to work, but there is no power coming out of the output plug.
          So output cord/wire would be my first suspicion when dealing with a faulty laptop adapter. A lot of owners just don't treat them kindly.
            HP ZBook ZBook 15u G3 Mobile Workstation Mobile workstation 15 Specification for Upgrade or Repair
            This specification for the HP ZBook ZBook 15u G3 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 15u G3 Mobile Workstation boardview and ZBook 15u G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
            09-06-2024, 05:30 AM
            HP ProBook 650 G3 + USB-C Universal Dock w/4.5mm Adapter Notebook 600 Specification for Upgrade or Repair
            This specification for the HP ProBook 650 G3 + USB-C Universal Dock w/4.5mm Adapter Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 650 G3 + USB-C Universal Dock w/4.5mm Adapter boardview and 650 G3 + USB-C Universal Dock w/4.5mm Adapter schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
            09-06-2024, 06:48 AM
