Samsung power supply BN44-00505A fault
  • ftwizard
    • Aug 2021
    I have a problem with my Samsung TV. I was sitting watching TV when suddenly, the TV went bang. I changed the fuse in the plug-top, and it went bang again.
    I thought I'd have a look inside at the power supply. I found a couple of diodes that looked burned, so i replaced them. It turned out they were okay anyway.
    On closer inspection, I saw a capacitor was blown out. I replaced that and although it didn't go pop again, it also didn't work either.
    The capacitor I changed was CM804.
    Any ideas why this cap should blow? would it be something to do with the device ICM801S.
    Thanks.
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Samsung power supply BN44-00505A fault
    Thanks.
    as per my experience, in most cases its the IC. why cap blows? age factor and dying parts. in your case, its the IC and the caps
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
      09-07-2024, 05:50 AM
    • cheeky2
      Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
      by cheeky2
      This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
      I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
      Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
      06-15-2025, 05:12 AM
      by sam_sam_sam
      03-31-2024, 02:12 PM
    • alltvrepairs
      Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
      by alltvrepairs
      I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
      I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
      Any one met this problem in the past?...
      10-08-2025, 07:34 AM
