Denon AVRX5200W/6200W SMPS
  • ponteley
    • May 2020
    • 4
    Hi everyone!
    Troubleshooting SMPS with output voltage fluctuation from 4.8V to 5.0V, spikes to 5.2V and back to 4.8 every 2-3 seconds.
    Replaced with brand new: both optocouplers U6501/02, rectifier D6515, U6503 IC.
    Primary voltage is stable 160V on C6506.
    T6501 secondary winding output AC voltage is stable
    Diodes tested OK. Caps OK. Resistors OK.
    Suspect D6524, but not sure....
    Any help is greatly appreciated!
  • Green Probe
    Recapping a Denon AVR X6400h SMPS
    by Green Probe
    (TLDR: It was capacitor C6519 [Koshin KZH 50V22uF] and C6515 [Koshin KZH 25V47uF] on the power supply. I have questions at the end)
    Disclaimer: I'm an amateur hobbyist and will get things wrong.
    Always use caution when working around mains power and high voltage capacitors!
    Hey guys, I'm repairing a Denon AVR X6400h for my brother. It quit powering on after a power outage. It acted like this last time there was an outage, but after letting it sit overnight it started working again for a few years. This time letting it sit did not bring it back.
    SYMPTOMS:
    -No display...
    07-18-2025, 03:36 PM
  • dkneyle
    Onkyo DX-V500 Laser Disc Player - weird SMPS fault
    by dkneyle
    This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
    Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
    02-01-2022, 02:08 AM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
  • madan1
    Mackie Th15 SMPS low Vout
    by madan1
    I'm troubleshooting a PA speaker Mackie Th15 (schematics attached).
    It is basically a smps with amp and some dsp.
    The issue is that on the secondary side I read +/- ~23V instead of the expected +/- 38V. Indeed all secondary side and feedback/aux rails are like 1/2-3/5 of the expected values.
    Q2, Q3, C35, C40, C33, C36, C41 and C42 were tested out of circuit with a component tester and read fine. Most of the other components on the primary were tested in circuit and seem to be fine. +HV to -HV on primary is ~330V.
    By the way, the ferrite core of L10 is broken,...
    02-16-2025, 04:15 PM
  • rewease
    Replacement for the Siemens Bakelite caps in an early 1980s SMPS
    by rewease
    There actually was a time when early SMPS and late bakelite housed electrolytic caps coexisted in high end industrial gear. A friend of mine just got himself a CNC milling machine form that time with its first set of now 41 year old caps still installed in the PSU... and it's malfunctioning.
    Two of the caps have already leaked slightly onto the board. I have not desoldered or measured any so far but they should qualify for replacement.
    Now I'm wondering what to put in there as a replacement. First idea was state of the art low-ESR Nippon KY,...
    09-17-2023, 12:53 AM
