Antec Earthwatts 380W +5VSB failure, wont turn on
  • Leopard
    • Mar 2008
    • 109
    • Finland
    Got a problem with one of these units.
    The power supply is visually fine, no broken / damaged solder joints, no burnt components or bulged caps. Caps are OST throughout the unit, except for the mains cap which is a Nippon Chemi-con.
    Symptoms are:
    Low +5VSB, below 2V
    The +5VSB voltage is very jumpy (changes rapidly from about 1.2V to 1.8V and also values inbetween)
    I changed the 3300uF 10V cap for the +5VSB but this didn't change anything.
    Any idea what could cause such symptoms if we rule out the caps and solder joints?
    EDIT: Also, if the I/O switch is flipped to the "I" position while the unit is in a computer, the power button wont respond and will keep flashing until the unit is turned off.
  • Toasty
    • Jul 2007
    • 4171
    Re: Antec Earthwatts 380W +5VSB failure, wont turn on
    Sounds like a small cap ahead of the 5vsb circuit. Usually 100uF or less ~50v.
    Only 1 cap on 5vsb out? I thought they used 2 across a pi filter. Also oddly high value. Somewhere around 1000uF-2200uF is more likely. hmmmm....?
    Not under warranty? How old is unit? Pics of area are helpful.
    Toast
    EDIT: If that's full of Fuhjyyu or OST caps or other crap caps, do a full recap on it.
    veritas odium parit
    • seanc
      • Nov 2008
      • 1319
      Do a full recap.
      I'm on my second now.
      1st was like yours, all OST caps, PC would not power on. I replaced every cap except the primary, it works fine.
      2nd was emitting a hissing/whine. It has OST and a few Teapo, in the midst of a recap.
      • Toasty
        • Jul 2007
        • 4171
        Knew you'd chime in from reading your other posts...
        veritas odium parit
        • everell
          • Jan 2009
          • 1514
          First you need to determine if the problem is in the motherboard or the power supply.
          Unplug AC cord from the wall. Then unplug the 24 pin power supply connector from the motherboard. Then plug AC cord back in the wall. Turn I/O switch to I. Now measure the 5vsb voltage between purple wire and any black wire on the power supply 24 pin plug.
          If measured voltage is 5 volts, the problem is in your motherboard. If the voltage is still low as before, your problem is in the power supply.
          Need to determine if problem is motherboard or power supply before we can be of much help.
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
          • Leopard
            • Mar 2008
            • 109
            • Finland
            Yeah I tried to run the supply without a motherboard. (Wont turn on via jumpering green wire + ground, purple wire to ground is 1.2-1.8V mentioned earlier)
            The PC this supply was in has already got a replacement supply (A Corsair unit) and it is working fine.
            I'll return with pics later.
              • 31163
              i wouldnt mind some foto's from this model - it's supposed to be better than true/smart power range.
                • 31163
                i dont know why, but everytime i read the first post i find myself thinking about optoisolators!
                • seanc
                  • Nov 2008
                  • 1319
                  I can get you photos of them after re-capping. Just imagine the Panasonic are OST or Teapo.
                  • Leopard
                    • Mar 2008
                    • 109
                    • Finland
                    Took some overall pictures - I can get better pics if needed.
                    Yeah I know the Nichicon is a bit old, but it tested good with an ESR meter.
                    • seanc
                      • Nov 2008
                      • 1319
                      Mine looks exactly the same, but dated 2007.
                      Down the side of the cables are 4 caps, are they all 1000uf 10v (like the first one I re-capped), or 2 x 1000uf 10v and 2 1000uf 16v (like the second)?
                      • Leopard
                        • Mar 2008
                        • 109
                        • Finland
                        The latter, 2 x 1000uF 16V and 2 x 1000uF 10V.
                        • Khron
                          • Sep 2006
                          • 1350
                          • Finland
                          I think this DOES have a pi-filter on the 5VSB. First cap is that huge (now) Nichicon, then there's that heatshrink-wrapped thingie in between the cap and the secondary heatsink (photo 2), that should be the inductor. And i've got a hunch that small black-with-gold-markings OST is the 2nd 5VSB cap, right between the secondary heatsink and the 5VSB wire (photo 1).
                          Wonder if and how healthy that little bugger is. Might not have fared too well, right next to that heatsink...
                          Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
                          • everell
                            • Jan 2009
                            • 1514
                            I have an Earthwatts 430 watt psu .... similar to yours. A couple of quick observations: this psu has active power factor correction (APFC), and has the Infineon ICE2A0565 pwm chip in the 5vsb circuit. This is an older design of Infineon pwm chip, and the frequency of the pwm oscillator varies with loading (20 khz to 100 khz). So this circuit may become unstable, especially over time. Download a data sheet on the Infineon ICE2A0565 and read up on this feature.
                            Working with 5vsb pwm chips, I did have one power supply that oscillated in a similar manner, and found that the output filter capacitor was too large. I replaced it with a capacitor with lower capacitance and it worked fine afterwards. You say that this psu has an output cap of 3300 uF. Sounds high for a 5vsb circuit. You might try changing to 2200 uF and see if that clears the problem. If not, put the 3300 uF back. I don't recommend changing values of any of the other components or the chip might explode.
                            I also recommend that all troubleshooting for this 5vsb problem be done with motherboard NOT attached to the power supply. You don't need to short green wire to black wire to simulate turning computer on. When you plug power cord to wall socket and turn power supply I/O switch to I, 5vsb should come on.
                            Be extra careful, and wear safety glasses when troubleshooting with power on. Safety glasses are not that expensive and protect your eyesight. VERY IMPORTANT.
                            • Toasty
                              • Jul 2007
                              • 4171
                              Check small cap next to smaller transformer in 2nd picture.
                              At the end of the clear plastic shield.
                              One I mentioned in my first post.
                              Replace all OST's.
                              Actually, any cap with a vent stamp on top, except main cap.
                              veritas odium parit
                              • seanc
                                • Nov 2008
                                • 1319
                                If memory serves correctly, the small cap Toasty mentions is a 47uf 50v cap, further down there is a 22uf 50v cap.
                                I would replace every cap (except the mains cap) just so I can be sure they won't cause a problem further down the line.
                                With regards to the 1000uf 16v, there were 3 in my unit and they were Teapo.
                                • jacobmj
                                  • Aug 2010
                                  Leopard, were you able to resolve this problem? I seem to have the same fluctuating, low 5VSB from time to time. It happens that every time I take it out and hook up the oscilloscope, it begins working fine...
                                    • 31163
                                    check the soldering first - i learned that from recent Antec stuff!
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      OP dropped subject and posted others since but never finalized this one so outcome is unknown.
                                      @ jacobmj - If your PSU is the same as this model, then follow the advice given everywhere in this forum about Antec PSU's - replace ~ALL~ the crap caps.
                                      If you have a different model, then start up a new thread and post up some pics so we can help you resolve this.
                                      Cheers & Welcome!
                                      Toast
                                      veritas odium parit
                                      • sirpsychol
                                        Antec Earthwatts EA-380 smd element type/value
                                        by sirpsychol
                                        While recaping Antec Earthwatts EA-380 I've broke one side of unknown smd element, it have no print, it's flatter and darker than smd capacitors on this board, shaped more like resistor but it's not resistor ofc. Unfortunetly the printed description was under it and element was glued to the board so I cant read/tell the letter before element number too. Have anyone any idea what it is? Maybe is there any diagram of this PSU?
                                        09-03-2023, 07:58 PM
                                      • Rgyver2
                                        Antec EA-430D 5VSB issue
                                        by Rgyver2
                                        I have an Antec ea-430d that will not turn on due to a problem with the 5VSB circuit. the TNY278PN has a burn "drain" pin (pin 4) and the two diodes (D901 and ZD901) near it look burnt with black on the board. (they were covered in that white goop which i removed).
                                        The TNY278PN needs replaced and likely the 2 diodes as well. I found the TNY278PN, but need to know what to order to replace diode D901 and the zener diode ZD901.
                                        From reading other posts, it seems wise to also replace the large 450V 270uf cap.
                                        The diode info and any other advice of what else to...
                                        04-18-2021, 12:00 AM
                                      • прямо
                                        Viper22A 5VSB circuit
                                        by прямо
                                        So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                                        In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                                        01-13-2024, 07:05 PM
                                      • kotel studios
                                        FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
                                        by kotel studios
                                        Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
                                        Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
                                        I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
                                        Any ideas where to go next?
                                        02-23-2025, 11:47 AM
                                      • Sus256
                                        HISENSE 65E7KQ PRO - no boot
                                        by Sus256
                                        Hi all!
                                        HISENSE 65E7KQ PRO
                                        RSAG7.820.13512 - chassis
                                        MT9618BAATAB - cpu
                                        RSAG7.820.12059 - power
                                        HD650Y3U77 - panel
                                        KLM8G1GETF - emmc
                                        Replaced emmc.
                                        Terminal log
                                        UART
                                        AC_ON
                                        E-B
                                        FDE enabled
                                        06-01-2025, 02:11 AM
