LiteOn PA-6601-1A (600w) blows its TOP
    Re: LiteOn PA-6601-1A (600w) blows its TOP
    Hello. Looking for D355
      What is it? Where? Picture or nearby area information please.
      veritas odium parit
        Schottky diode in SOT-23 package.
        Marked 5H.
        From Post 58.
        Which crosses to MMBD701.
        veritas odium parit
          Just wondering if anyone found the problem when these supplies take out F1, R302 transistor and caps on the primary side?
            Hi guys I'm new here, I was troubleshooting one of these power supplies and was able to narrow the problem down thanks to this post. Unfortunately b4 I found the problem I futher damaged the PS whole troubleshooting, another component burnt besides the R302, it's the resistoe next to the relay. I can't identify it cause it broke apart. Can anyone tell me what type and value it was?
              >>Just wondering if anyone found the problem when these supplies take out F1, R302 transistor and caps on the primary side?<<
              Primary caps?? Never have seen that...?
              >><snip>...I can't identify it cause it broke apart. Can anyone tell me what type and value it was?<<
              I can't help you until you reveal its ID number. R???
              Toast
              veritas odium parit
                i can't id the part cause it was glued to the board with white epoxy like adhesive to the main relay and i can't remove the epoxy from the board to see the part number. it's the part that is with REL1
                  Picture. There are different parts surrounding the relay.
                  See post #12 for a picture.
                  veritas odium parit
                    Ok so looking at pic 2 from post #12 its the greenish circle glued to the side of REL1. (I'm on my phone right now so when I get home I'll take a pic of where it was )
                      You burnt THAT!?!? OMG!
                      Did the fuse blow too?
                      You must have -really- pissed it off!
                      veritas odium parit
                        Lol, yes I did ..... my initial troubleshooting approach was a bit primitive....
                          Inrush Current Limiter, NTC thermistor
                          SCK-055 - All at 25°C:
                          5Ω cold resistance
                          5A max. constant current
                          166mΩ working resistance
                          This will work and with a bit more current handling:
                          http://search.digikey.com/scripts/Dk...me=495-2103-ND
                          Use a 100w to 200w light bulb in series with mains when testing. Saves fuses and these.
                          See post 23 here:
                          https://www.badcaps.net/forum/showthread.php?t=7165
                          veritas odium parit
                            thanks yur a life saver
                              Toasty -- I was referring to C301, 302 and 303 not the mains. Duties have pulled me off this p/s but I still have "a ton" of them around and it bugs me I was never able to fix this problem.
                              Sigma -- please post if you are successful in repairing your supply. It's the burnt R302 problem, right? Known things that go are F1, R302, Q301 & Q302 and C301,302 & 303. Would love to know if you are successful.
                                Originally posted by jf1452 View Post
                                So after replacing U801, Q856 and OPTO851, I have a fully working PSU.
                                Hi all. I have the same problem. I have replaced the TOP, its cap, Q856 (with a bc557) and OPTO851 (with a sharp pc123). It is still dead...what to replace now?
                                Seems that Q856 lowers TOP's frequency in stand by mode. A way would be tring to bypass some circuitry as the TOP should work "alone". What do you think?
                                -Alez
                                  Do you get any "relay clicking" on the primary? All the other stuff (F1, R302 etc. mentioned in post 94) checks out?
                                    No, there is no sound. Stuff in the main supply section seems ok. Simply stand by supply does not work, the TOP is freezed by some side circuitry.
                                    I'm using a 220 to 110 V transformer + a 150W bulb shunt. I correctly read 160VDC on the primary power rail capacitors. It's probably some transistor near Q856, but it's not easy to test&replace all as they are smd...
                                      The measurements that follow are done on the electrically HOT side with respect to earth ground. Contact by any part of your body with any exposed metal traces or components including but not limited to heatsinks, may result in injury or death. Follow the "one hand in your back pocket" rule when probing for these voltages.
                                      Measurements are taken with the negative of your meter connected to the negative post of the bridge rectifier or like termination.
                                      Set Meter to 20v DC range.
                                      Confirm the following voltages at TOPSwitch TOP249YN with the power supply in Standby mode -
                                      Pin 1: 5.8v
                                      Pin 2: 2.4v
                                      Pin 3: 1.3v
                                      Pin 4: 0v
                                      Pin 5: 5.8v
                                      Set Meter to 200v DC range or higher.
                                      Pin 7: 167v
                                      Toast
                                      veritas odium parit
                                        Thank you Toast for providing me those voltages... are those values taken from a working supply?
                                        The readings at the TOP are quite identical:
                                        Pin 1: 4.9v
                                        Pin 2: 2.5v
                                        Pin 3: 1.1v
                                        Pin 4=0v
                                        Pin 5: 4.9v
                                        Pin 7: 160v
                                        HDC rail: 160v
                                        If I connect a 10k resistor between pin 1 and base of Q856, then pin 5 goes to 0v, but the circuit still doesn't work.
                                        Alez
                                          Taken from a working 5v & 25v standby supply. The rest is still not working.
                                          If those are present, then the TOP is working correctly. The ~160v output feeds directly to the standby transformer.
                                          I've not gone back to figure the rest of the circuit.
                                          veritas odium parit
