HEC-250LR-T with (or rather, without) exploded resistor
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    Seems like PSUs like blowing up on me recently...
    Plugged in this old P3 system I have, didn't get far after hitting the PSU switch and there was a small popping noise
    Took me a while to find it (I guess the lack of burnt silicon smell should have been a good sign) but eventually I found two leads either side the silkscreen of an R where there should have been a little resistor.
    It seems to be part of the circuitry for the controller\monitor ICs
    Fortunately I have an identical PSU so I can find the value easily but why would this resistor just outright explode (either that or vaporised, I can see no traces of it) I can see no damage to surrounding components either...
    -David VanHorn
  • everell
    • Jan 2009
    • 1514
    Re: HEC-250LR-T with (or rather, without) exploded resistor
    In recent weeks I have worked on a HEC-300AR-TF which is probably similar. It has a AZ3843 for pwm chip and P10NK60Z FET (10 amps 600 volts) for the switching transistor. There are only two transformers between the two heat sinks, the smaller one for the 5vsb circuit and the larger one for the main switching circuit. Since this psu does not have a third transformer to isolate the pwm chip from the main switcher - when the main switcher shorts, as in the power supply I worked on, the 320 volts from the main caps goes to the pwm chip, taking out any small resistors in the way.
    So.........measure the resistance of the main switching transistor. If it is zero, or near zero, you can figure that the pwm chip was also fried, as well as some other components in the vicinity. Perhaps challenging, it can be fixed.
    Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
    • Bivolalbert
      Help figuring out the resistance of this exploded resistor. gtx 1060 6gb inno3d compact
      by Bivolalbert
      Hello,I need help figuring out the resistance of this exploded resistor. I'm pretty sure it's the one labeled R37. I tried measuring it with a multimeter, but I got different values each time, probably because it's exploded. If you have a schematic, it would be really helpful!
      Its a gtx 1060 6gb inno3d compact, i you have schematic it would be very helpful....
      02-13-2025, 10:30 AM
    • jinu_j
      by jinu_j
      Hi
      05-03-2025, 10:51 PM
    • mikey5791
      by mikey5791
      Hi to all forum members,
      12-26-2024, 04:55 AM
    • MidnightRoller
      Can a resistor lose resistance after hot air?
      by MidnightRoller
      I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
      I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
      02-02-2022, 11:46 PM
    • artvandalai
      What resistor ohm will work better to repair this waterpik?
      by artvandalai
      The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
      01-05-2025, 04:10 PM
