OCZ modxstream pro 700w blowing fuses
  • Sylvester
    • Nov 2006
    • 67
    3 week old ocz blowing mains fuse, it was hooked up to a p4i65g 478 mobo so nothing it can't handle. Reconnected original oem fsp 250w and all is fine with the mobo.
    Any ideas what the problem could be? I thought this was a reasonable psu, obviously not!
  • Sylvester
    • Nov 2006
    • 67
    Re: OCZ modxstream pro 700w blowing fuses
    No problems with this one, got a refund from store, have now ordered a corsair vx550w.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4914
      • New Zealand
      A short circuit in a primary-side component probably
      -David VanHorn
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • Sik_6ty_Sixx
        HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
        by Sik_6ty_Sixx
        So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
        02-18-2025, 05:06 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
        1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
        I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
        This metal lathe has a weird motor setup it has a soft start motor with a ā€œYā€ and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
        12-29-2024, 07:18 AM
      • mon2
        Gemsound PAX-105 Audio Amp blowing fuses
        by mon2
        Hi. New to this side of the forum.
        Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
        Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
        Thanks.
        10-30-2024, 08:33 AM
