Delippo charger voltage question
  • tdr
    • 30
    • Lithuania
    I bought this charger from eBay, the price was decent, not the cheapest one and I thought I bought a good quality charger for my tablet and maybe, occasionally for the phone charging also.
    The specs says:
    Input 100-240VAC 50/60Hz 0.6A
    Output: 5V 2A
    Safe voltage output to charge phone, right? At least, that what I thought. Well, I tried that and trusting I bought quality charger -what could go wrong- I plugged in my phone and it instantly froze with black screen. I restarted it by pressing power button for 10 seconds and it turned on. What a relief! That what I thought until I plugged in my regular charger to the phone charging port. It was dead, no charging anymore. Long story short, after sending it to repair service, they didn't have the detail for the specific charging circuit, I trashed it and got new phone.
    The story continues. I then tried the Delippo charger with my old colorfly g708 tablet that I was not afraid to loose in case something goes wrong (btw, exelent tablet with good specs, loved it, used many years until I broke screen 3rd time and the replacement touch screen was dead and then I broke my usb otg port and finnaly gave up). When I plugged my tablet to the charger, the screen went crazy with erratic movements and freezes but the tablet was fine after unpuging and the charging port was not damaged thankfully.
    I then emailed the seller and they send me replacement. After I received it, I tested it again on the tablet. Same erratic movements and freezing screen. When I told the official Delippo seller that I damaged my phone, he insisted, that the charger was ment for tablet and not phone, when I replied that the specs rated it 5V 2A charger and it should be fine, he had nothing to say, if I recall, he offered to send chargers back or something, it was some time ago so I don't recall exactly what the conversation was. Sure enough they didn't compensate my 200 plus euro worth phone.
    So here goes my question to you, my dear badcap members:
    is there something wrong with both chargers or my understanding that all micro usb chargers within the same specs should be the same? Isn't 5.75V and 5.65V out of the 5V tolerance levels?
    Here are the pictures and voltage measurement I took (1st charger 5.75V, 2nd charger 5.65V or so). On circuit board to the solder points the voltage did not measure at all for some reason but only at the micro usb connector end. Is that normal? What can you tell looking at the pictures, does it look like normal quality charger and what could be wrong with it?
    • Jul 2011
    • 6024
    Re: Delippo charger voltage question
    The specs says:
    Output: 5V 2A
    That voltage of 5.75 amp is high for a 10 foot cord the most voltage at the charger is at 5.25 volts
    with a 3 foot cord the voltage should not be higher 5.1 volts and this on the high end 4.90 to 5.00 is more like it
    One word of advice is to buy your self a USB voltage and current meter
    There are two versions of this one displays voltage and then current
    The other version has both the voltage and current displayed at the same time this my favorite one to use ( Do not trust website vendors for USB switching power supply the specifications are sometimes a lot better than they are
    • tdr
      • 30
      • Lithuania
      The cord is about 4.9ft. (150cm) long 22AWG, the 5.75V voltage was measured at the farthest end (I cut the micro usb connector because I will not use it for charging purposes anymore), it didn't measure at all at the adapter circuit side, maybe because of no load but whatever.
      I have something like this at home https://www.aliexpress.com/item/3293...65585f0f7j7A02 and if I recall corectly it measured similar voltage not so sure about current draw, I think I also needed to do some wiring because the lack of micro usb port on the usb meter...
      My main concern is why it fried phone charging circuit and didn't work as tablet charger? Is it because 1) both chargers, including replacement, were defective (isn't it bit weird that both are the same?) or 2) there is something out there that I don't understand quite yet about chargers? The specs are 5V and 2A rated, shouldn't it be enough for at least *safe* (if not recommended) use in all 5V usb charging compatible devices, at least so that no damage is done?
      • R_J
        • 9516
        That adaptor looks like it has very poor regulation and filtering for the output. I would have thought it would have a 5 volt regulator ic for the output at least. I would not use it anything like a phone or tablet.
          • Jul 2011
          • 6024
          TDR
          The one you posted the website link is the type that I was talking about and the one I prefer to use
          All you need to use with this device is the phone charging cable is all you need
          These switching power supply can be modified for charging phones and tablets this is the 8 amp version but they also made a 5 amp version the 5 amp version is one you want to use
          https://www.ebay.com/itm/Ault-5V-8A-...53.m1438.l2649
          One thing that is nice about these switching power supply is that the output voltage can be fine tuned from about 4.80 to 5.5 volts or maybe a little higher than this but most of the time I set it for 5.25 volts and works very well
          One note if get one of these power supply is to recap before you use it
          It has non brand name capacitors in it
            What Voltage do you get when loaded it with 2A load?
            Monitor the Voltage when the load is connected and disconnected to see how high it jumps up to and go down too.
            It may have poor regulation.
              • Jul 2011
              • 6024
              The switching power supply that mentioned earlier with a 2 amp it drops down to about 5.00 or so when using a 10 foot cord
              With a 3 foot cord it does not drop as much about 5.19 volts or so
                I did not see OP mention anything about testing with 2A full load result.
                OP" "The cord is about 4.9ft. (150cm) long 22AWG, the 5.75V voltage was measured at the farthest end (I cut the micro usb connector because I will not use it for charging purposes anymore), it didn't measure at all at the adapter circuit side, maybe because of no load but whatever."
                  • Jul 2011
                  • 6024
                  I was referring to the USB switching power supply that I use I was giving this as example
                  • HERETIK10
                    Adaptable charger voltage for Clevo D901C laptop
                    by HERETIK10
                    Thanks in advance to anyone who takes the time to help me. Sorry for the quality of my English, I had to use a translator at times...
                    I bought a functional Clevo D901C (Sager NP 92261) with its battery but without its power supply.
                    So, I invested in a new LiteOn charger, advertised by an online seller as the right charger for my machine... BUT, according to the pinout (4pin + shell) of the charger, 1 and 2 are 20V / and 3 and 4 are grounded. When I measure pin 4 with the ground of the PC, I have 300kOhms, which seems to be confirmed by the electrical...
                    11-08-2023, 04:24 PM
                  • flat-earther
                    ASUS X54H laptop thinks it's always charging even with charger unplugged
                    by flat-earther
                    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                    Windows also shows ''Plugged in'' when charger is not connected.
                    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                    If I let battery run out and say it has 3% Windows will...
                    06-24-2025, 09:32 AM
                    HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                    This specification for the HP Elite x2 Elite x2 1012 G2 Tablet (ENERGY STAR) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet (ENERGY STAR) boardview and Elite x2 1012 G2 Tablet (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-06-2024, 07:10 AM
                    HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) 1012 Specification for Upgrade or Repair
                    This specification for the HP Elite x2 Elite x2 1012 G2 Tablet Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite x2 1012 G2 Tablet boardview and Elite x2 1012 G2 Tablet schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                    09-06-2024, 06:30 AM
