View Post
I have another controller that just like this one and I going to swap them around because this station has the hot air gun on the other side of soldering iron
which I do not use very often unless I am doing multiply layer board and I need the extra heat to unsolder a component
When you saying about using a laptop switching power supply any particular brand should I use it might be hard to find a 19 volt @ 12 amp laptop switching power supply I will look at EBay and see if I can find one and I will post the website link to it just let me know if you think it would work or not
If can not find anything wrong with the switching power supply that has the cycling power issue would you be willing to take a look at it and see if you can figure out what is wrong with it
I found this one do you think that it would have enough current capacity for the the soldering iron side of the station
do you think that it would have enough current capacity for the heater element and the vacuum pump plus the cooling
https://www.ebay.com/itm/25636685625...Bk9SR_bQ8aezYw
