Pro-Logic Smart Battery charger
  • kenwoodhf
    • Feb 2020
    Hello all. This is probably a long shot but I am hoping someone out there can help me. I have a Pro-Logic PL2510 smart battery charger that doesn't work. It goes though its start up routine but will not display the proper batty voltage when a battery is connected. There is not allot of electronics on the board so I decided for the $3, I would replace the 3 integrated circuits. No change in operation. The MCU is a PIC18F25k22 and I was able to extract the HEX code and reinstall it into the new IC. There is a programming header on the circuit board. After experimenting putting in different voltages I come to the conclusion that the MCU is not calculating the voltage correctly. I called the manufacture for help but they said this is a throw away product and no support is available. I believe that the program has been corrupted, so what I am asking is if anyone out there who might have this model charger is willing to extract the hex code and send it to me? I am a hobbyist and this become a challenge for me. I can disassemble simple code programs but this is far to complicated for me to try.
    Thanks Jan
    • Jul 2011
    • 6070
    Re: Pro-Logic Smart Battery charger
    You need to two things first
    You need to post a picture of the front of the power board and then the back of the board
    You also need to post pictures of any other boards that are in this unit front and back of these boards
      NVDC charger configuration...
      11-05-2024, 03:28 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
