Power supply blowing fuses in Zebra 2746e thermal printer.
  • torin3
    • Aug 2009
    • 178
    Re: Power supply blowing fuses in Zebra 2746e thermal printer.
    Originally posted by Gianni
    It's low but it is the min Vcc accepted by TL494.
    I'm still curios to know where the voltage comes from.
    Well, I orded a replacement one anyway, just to be on the safe side.
    R1 is to far from IC1 I think it is not the start up resistor, it's value is 820ohm probably 1W, the value is too low for start up.
    If you read 50Kohm be sure all caps are discharge, you can lift on leg and measure it disconnected. If it is 50Kohm then replace it with 820ohm 1 or 2W.
    Disconnected it has an even higher resistance. I'll order a replacement tonight.
    Looking at the pictures I see IC3 near D13: have you identified it?
    Maybe it is another part to check.
    Ciao
    Gianni
    Yep, BT137-600D. Triac. Datasheet is here:
    • torin3
      • Aug 2009
      • 178
      Oh, and the only larger resistor on the board is R4, which if I'm reading it right is 2.7Kohm. (Red, violet, red, gold).
      It reads lower resistance than that. It is hard to tell on my analog meter, but I'm getting the same reading as when I touch the probes together, so I should assume it is shorted?
      Edit: Nevermind, I borrowed the DMM, and I lifted the leg. 2675ohms.
      • Toasty
        • Jul 2007
        • 4171
        R1 = White-Red-Orange-Gold = 92k ohm 5%
        veritas odium parit
        • Gianni
          • Jul 2008
          • 681
          • Italy
          Well R4 is just a bleeder on the output, measure it disconnected because it is in parallel with the output and maybe it takes time to charge the output caps. It is a dummy load to keep the PSU in tolerance with no load/light load and to discharge the output caps when it is disconnected from mains.
          So IC3 it is a triac, probably it is part of a crowbar to blow the input fuse for input overvoltage protection.
          The bigger resistor on this PSU is the white one behind the trafo, it is 5W but can't read the value. probably a snubber on the primary side, I can't follow the tracks.
          Let's wait til you have replace IC1.
          Ciao
          Gianni
          "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
          H. J. Brown
          • Toasty
            • Jul 2007
            • 4171
            Big white resistor is 22 ohm.
            (Lower left) What about R2(3?) and Q1? Also, what is DIC1? I can make out 125v on the side...?
            >>It reads lower resistance than that. It is hard to tell on my analog meter, but I'm getting the same reading as when I touch the probes together, so I should assume it is shorted?<<
            You likely forward biased a nearby component. When that happens, reverse the leads and see.
            Toast
            veritas odium parit
            • torin3
              • Aug 2009
              • 178
              #26
              Wow! Good eye. I would have sworn it was brown until I compared it to the other resistors of the same type.
              Pulled and checked. 22.2 ohm.
              (Lower left) What about R2(3?) and Q1? Also, what is DIC1? I can make out 125v on the side...?[/QUOTE]
              R2 and R3 are both 1000 Mohms. (brown-black-grey-gold). Q1 is a transistor that was bad. I've replaced it already. This part: http://www.mcmelectronics.com/product/2SC2625
              DIC1 has 3 markings on it. There is a logo type ST symbol, followed by a block letter E. Next line down is DB3, and the line below that is X527 (what looked like 125V).
              • Toasty
                • Jul 2007
                • 4171
                #27
                Ok, my mistake. I can't see the markings directly. It's the large gray resistor next to SQ1, as I was directing your view to the lower left. I went to an earlier pic, it's SR3. Then I also need to go back to the previous question about Q1 in which I really should have said SQ1.
                DIC1 is a Diac:
                "Functioning as a trigger diode with a fixed voltage reference, the DB3/DB4 series can be used in conjunction with triacs for simplified gate control circuits or as a starting element in fluorescent lamp ballasts"
                Once the voltage across it rises to a value of about 32v, it conducts and remains on until the current value drops below a certain point. It's in the gate circuit to that triac IC3. So, as Gianni said, it's part of a crowbar circuit.
                When checking resistors in circuit, they will present as the value marked or lower. If it reads higher, then it's failed. So 50k on that 92k resistor was fine. If it had read 150 k then you would be suspicious.
                You are replacing the 494, correct?
                Toast
                veritas odium parit
                • torin3
                  • Aug 2009
                  • 178
                  #28
                  No problem. SR3 is yellow, violet, orange, gold, for 47 Kohms. I'll pull SQ1 out and test it. (That would be resistance, switching pos/neg on all the leg combinations, plus the part number?)
                  DIC1 is a Diac:
                  Toast
                  Yes, the 494 should be in about 10am tomorrow.
                  • torin3
                    • Aug 2009
                    • 178
                    #29
                    Forgot to say SR3 tested about right on with the resistance.
                    SQ1 is part number MPS2907A and positive probe on the center lead reads about 3 Kohm to leads 1 and 3. Positive probe on leads 1 and 3 reads infinite on all other combinations.
                    • torin3
                      • Aug 2009
                      • 178
                      #30
                      Ok, I replaced the 494 IC and it still doesn't work.
                      No lights come on at the front of the printer, and the little LED1 on the board doesn't light up. I haven't tried putting a fan in the socket for it yet, but I can if someone wants me to try. Any suggestions?
                      • torin3
                        • Aug 2009
                        • 178
                        #31
                        I'm heading home in a few minutes. Should I take the printer with me, or are people running out of troubleshooting ideas?
                        • torin3
                          • Aug 2009
                          • 178
                          #32
                          Ok, taking home just the PSU.
                          Fan header has 1.6-1.7 volts going to it.
                          That is about 1/7 of the voltage it should have. Does that lend itself to any suggestions?
                          Edit: Found a fan with the right header. Fan doesn't move when the PSU is turned on.
                          • Toasty
                            • Jul 2007
                            • 4171
                            #33
                            I have some voltages I'd like you to check, but I need to mark the test points on the photo(s).
                            In a bit...
                            Toast
                            veritas odium parit
                            • Toasty
                              • Jul 2007
                              • 4171
                              #34
                              Okay, here's the pic.
                              Please take readings for each of the 6 numbers at the points indicated and report.
                              I marked the IC pins 1 & 9 so I (we) don't get confused when tracing.
                              I also marked the board between the Hot (mains) side and isolated side. You should be doing any measurements on the Hot side while using a isolation transformer (trafo). Please be careful not to come in contact with any components on the left side of the yellow divider.
                              @Gianni - The supply for the IC and the other components there comes from the C26 cap and the diodes D23 & D24. It's a center tap, full wave arrangement off the large trafo.
                              Toast
                              veritas odium parit
                              • torin3
                                • Aug 2009
                                • 178
                                #35
                                I don't have an isolation transformer. I should skip the reading for 1 then?
                                • Toasty
                                  • Jul 2007
                                  • 4171
                                  #36
                                  Not at all, just be very careful when you do so.
                                  Toast
                                  veritas odium parit
                                  • Gianni
                                    • Jul 2008
                                    • 681
                                    • Italy
                                    #37
                                    I have no more suggestion since I can't figure out in which way the TL494 starts.
                                    I see SCR1 and some diodes around IC1, check if they are OK; I don't know what SCR1 does in the circuit but you can identify it and check the connection/voltages, maybe it is damaged and it block the circuit. I think it could be a latch for output OVP.
                                    I hope Toasty will be able to help you.
                                    Ciao
                                    Gianni
                                    EDIT: Toasty you are right about C26/D23/D24 and trafo but before the trafo creates the voltages, the TL494 must starts. C26 must be charged through a resistor or something else. I hope my doubt is clear for you
                                    H. J. Brown
                                    • torin3
                                      • Aug 2009
                                      • 178
                                      #38
                                      Toast
                                      0 Volts DC on 1 through 6.
                                      • Toasty
                                        • Jul 2007
                                        • 4171
                                        #39
                                        I thought you had 7 volts on IC1...?
                                        Try it on AC scale or reverse the leads on DC.
                                        veritas odium parit
                                        • torin3
                                          • Aug 2009
                                          • 178
                                          #40
                                          SCR1 is
                                          CR02AM
                                          8 5F
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • Sik_6ty_Sixx
                                            HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
                                            by Sik_6ty_Sixx
                                            So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
                                            02-18-2025, 05:06 AM
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                            1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
                                            I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
                                            This metal lathe has a weird motor setup it has a soft start motor with a ā€œYā€ and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
                                            12-29-2024, 07:18 AM
                                          • mon2
                                            Gemsound PAX-105 Audio Amp blowing fuses
                                            by mon2
                                            Hi. New to this side of the forum.
                                            Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
                                            Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
                                            Thanks.
                                            10-30-2024, 08:33 AM
