The windings of an ATX transformer & other
  • Atoss
    • Jul 2019
    • Latvia
    // Disclaimer: I am acutely aware that what I am trying to achieve can be had in a smaller and safer package for under 10 €. That, however, does not include any learned experience, nor does it reduce my hoard of power supplies (nor does it include lethal danger, but for now, let us pretend that I'm suicidal). Thank you for attention.
    With that said, the situation: I am trying to coerce an ATX power supply into outputting a higher voltage. Given that it's a typical DBL494 affair, the textbook method of duty cycle adjustment has already been applied - adjusting the voltage divider at pin 1, and 4.7 kΩ pulldown from pin 4 to ground for minimum deadtime to disable OVP. (I tried to modify it for higher voltage first. Spent the better part of a day tracing out what connected to the deadtime pin, before getting lost in the circuit jungle. Still didn't find a connection to any of the voltage rails) This works, but at 16 V the supply starts emitting a noticeable chirping sound, which I guess I should take as a no. Alright, onto the transformer. I desoldered it to bet a better look and realised that Ihave no idea how the secondaries are wired. Until then, I was under the impression that 12V is a regular centre-tapped winding (judging by the two-diode rectification) and 5V/3.3V are something more exotic (judging by the PCB). What's visible with XFMR off the board seems to suggest otherwise - the fat 0V wire coming out the top consosts of 8 strands. Unfortunately, I can't properly figure out what is between them and XFMR's secondary pins due to the low DC resistance - a DMM can't tell if it's an actual short or a winding. Thus I can't tell, whether it might be possible to, say, connect the 5V and 12V windings in series, or where do I put extra windings if that's a better way.
    Even if this is impossible without blowing up parts on the secodary side (I've upgraded the electrolytics to higher voltage rated ones, but nothing else) I'd still be grateful for an answer on how that transformer is laid out - for curiosity, if nothing else. Or a method for finding that out - I was thinking a signal generator with a resistor in series, then watch the voltage drop over the resistor - sensible? No?
    Oh, and the target voltage is 17-19V, for powering a laptop motherboard. Tried giving it 12V through the battery inputs, wouldn't take. Since the original battery is long gone, I assume it would be pretty hard to simulate battery's responses with a microcontroller.
  • noppa
    • 42
    Re: The windings of an ATX transformer & other
    This might help you
    http://www.chirio.com/switching_power_supply_atx.htm
    • Atoss
      • Jul 2019
      • Latvia
      Originally posted by noppa
      Hmmm, interesting. Haven't run it through Google Translate yet, will do later. Although if the transformer is really wound like shown in these schematics, theņ I assume some sections would have to be doubly-wound? Why? To get higher current without switching to a different wire gauge?
      Also the idea of using a 4-diode rectifier seems promising. Has anyone else tried that?
      • UserXP
        Transformer producing higher voltage than rated
        by UserXP
        Hello, people.
        i am not sure if this question belongs to this forum section exactly, but since there already are some queries here about power transformer, let's give it a try.
        So, I have this old but very well preserved Casio SA-20 ToneBank keyboard. It is powered either by five 1.5V AA bateries, or via a power adapter, so its operating voltage is 7.5V. The power adapter input jack also states 7.5V DC In. Now, since this keyboard was never supplied with a PT, but actually came with test bateries included, I decided to try to buy an adapter for it. I know I could have just gone...
        09-02-2025, 12:42 AM
      • tvguy12012012120
        Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
        by tvguy12012012120
        This is the zombie UN55NU6900F I wrote about in this original post.
        It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
        The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
        1. What could cause the standby voltage to be 1V higher than expected
        2. Is this a problem
        3. Could it have led to the failure at RM819, or was that...
        02-12-2025, 11:22 AM
      • rstrube
        ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
        by rstrube
        Hi Everyone,
        I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
        Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
        11-23-2025, 12:19 PM
      • Fernon@Repair
        Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
        by Fernon@Repair
        i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
        VCCIO voltage ok
        VCCSA Voltage OK
        VCCPLL Voltage OK
        Ram Voltage ok
        RamVTT OK
        VPP 2.5 OK
        But No Core Voltage
        and i want to this vrm ic datasheet or pinout (ISL69269)
        anyone have this ic pinout voltages?...
        06-25-2025, 07:19 AM
      • C152Heavy
        Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
        by C152Heavy
        Summary for TL-DR readers:
        • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
        • Have obtained Samsung schematic & service documents - Can upload if helpful.
        • Have read ALL applicable threads
        • C1818 and CP820 replaced as low hanging fruit
        • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
