This is a sticky topic.
No worries, it's the HP-P3527F3... which is my exact model (except mine has a manufacture date of May 2006 and yours May 2007, and both are the lead free versions I believe), meaning it has a high speed sleeve bearing fan from ADDA. If it has SATA connectors and a 24-pin ATX connector, then it's the HP-P3527F3W.Last edited by Wester547; 04-28-2013, 10:55 PM.
Originally posted by bobcaygeon View PostKentek KTPS-850
<snip>I love putting bad caps and flat batteries in fire and watching them explode!!
Bought a set of screwdriver bits with almost all the obscure tips:
So i decided to "celebrate" by investigating the insides of an adapter that I had around for about a year but i couldn't open it before because it was using security screws (the ones like an Y)
Quite nice construction, tl431 reference on the secondary with the slider changing a resistor... two transistors on the primary side, the main one heatsinked well and even had thermal paste (but i didn't want to desolder it to see exactly what it was)..
cabled with heatshrink at the mains socket
1n4001 diodes for bridge rectifier (quite enough for a 12w max adapter)
fuse
22uF 400v main cap (jicon 105c)
2 105c 470uF 25v on the secondary that I don't recognize the logo (like a pyramid viewed from above), with K vent.
quite big clearance between the sides, y cap for emi filtering...
quite nice for something that was under 10$
It's also just a two transistor circuit and but at least it does not use the killer cap.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
1N4001 diodes would blow up when used on the high voltage of the mains! Did you mean 1N4007?
Anyways that pcb is of a crappy material, and likely rifeking caps too ... yuck!
Ran this for hours with a couple of 12v fans (so about 0.4A) and it barely got warm, so not too concerned about the capacitors, it probably only goes up to 40-50c.
I didn't even expect the transistors to have a heatsink so I was a bit surprised seeing even thermal paste and heatsink and the pcb locking in place on top of the channels for the screws.
It's not just a pcb that slides between two plastic poles like I see on some Chinese adapters.
Believe it or not, a beautiful looking Allied. Built by Solytech but still....
For input it has 4 Y caps, 3 X caps, 2 coils and an MOV. Switchers are made by Fairchild, huge transformersSurprised to see Teapo in a Solytech I thought they would have used YC. I will probably replace all the Teapo though except for the primary cap, I might order one anyways though... The soldering, not so good
On the secondary it has dual 30A shottky's for 5V and 3.3V and dual 50A schottky's for 12Vand it even has OCP. The fan is a sleeve bearing Globe Fan I will probably relube it. I like this PSU for only $28
epower, so topower? Although it has ZU on the transformer, so Zumax?...I don't think it could do 600W but it looks to be a decently built power supply, I was thinking maybe 400W?
The input caps look good (and they're actually rated at 105C), it's got a nice input filter with MOV's, and surprisingly a 10A bridge rectifier. Couldn't find any datasheets for the primary MOSFET's, there are 2 and they say P1488 on them. Transformer looks good...it has a S30D45CS shottky for 3.3V and 5V, and two MBR20100CT rectifiers for the 12V, it has two groups of 12V wiring but no OCP as far as I'm aware...All the secondary caps are YHC (never heard of them) and ChengX (Just on the 12V) Think it could do 400W?
Originally posted by Pentium4 View PostCouldn't find any datasheets for the primary MOSFET's, there are 2 and they say P1488 on them.
Originally posted by Pentium4 View PostAll the secondary caps are YHC (never heard of them).
Originally posted by Pentium4 View PostThink it could do 400W?
(that is, if you want ripple to be in spec too).
Are the two 20A rectifiers for the 12V going to two separate 12V rails or are they in parallel? If the latter, don't expect to be able to pull 40A on the 12V rail.
Originally posted by momaka View PostShould be NPN BJTs, not MOSFETs since this is a half-bridge design. I couldn't find any info either, though.
Judging by the "LOWESR" written on their sleeves, I can kind of guess how "good" their quality is.
Depends on what the primary transistors are rated for. The secondary side filtering looks average, so I would say 350W yes, but 400W... maybe
I will replace all the caps except those Fhy ones. If i increase the capacitance with better caps it should be in spec? It has 2x 3300uF for 12V plus an inductor. I will have to double check to see if those rectifiers are in parallel or not
Originally posted by Pentium4 View PostIf i increase the capacitance with better caps it should be in spec? It has 2x 3300uF for 12V plus an inductor. I will have to double check to see if those rectifiers are in parallel or not
I don't know, those look really small to be 3300uF @ 16v
There are Panasonic FR 1800uF 16v @ 10x25mm , 10k hours @ 105c.
For 300-450w power supplies, they should be enough to keep ripple to reasonable levels.
There's FR, 2200uF 10v @ 10x25, still 10k hours @ 105c
If there's pi filter arrangement there, then they should really be enough to keep ripple and stuff in check.
Originally posted by mariushm View PostI don't know, those look really small to be 3300uF @ 16v
If there's pi filter arrangement there, then they should really be enough to keep ripple and stuff in check.and I will test the values of those ChengX caps and report the values
Originally posted by mariushm View PostI don't know, those look really small to be 3300uF @ 16vLast edited by Wester547; 05-04-2013, 04:54 PM.
I have Samxon RS 3300 uF/16 V in D10 on the way if you are interested…Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!
I'm not claiming anything about the capacitors being fake or not. They're just suppositions. I agree the size doesn't always mean anything, there's lots of various sizes.
Some other guesses... they might be 3300uF 16v, but they might be only 85c capacitors labeled as 105c or who knows, the aluminum can might be super thin allowing for a bit more capacitance compared to brand name capacitors, or they might be 3100uF which is close enough to 3300uF (20% tolerance) etc etc
Well from what I have seen so far, crap manufacturers and Samxon only have such capacitance in D10. As for Samxon, I think the quality is proven now. As for the rest, the "quality" is proven as well, isn't itI think it is not uncommon for some of them to hold nominal capacitance even for just weeks after coming from factory, right.
