MC2100els-50w treadmill blown PSU help
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    Good day folks. Today I've got something kinda special: it's a power supply/motor control unit for a treadmill. When I got it, it was in pretty bad shape: a lot of blown components on it, but thankfully someone before had replaced most of them...not sure if the values are correct, but better than nothing. Problem is that it's still missing two components, both SOT-23, making the job very difficult. Have a look at the pictures: the STR G6653 SMPS IC was blown and the missing parts are linked to its VCC pin. A quick look at the traces pretty much tells me this is a linear regulator using a zener and a transistor. The transistor's collector comes from the "VCC AUX" rectifier diode directly above the heatsink, the emitter is the "output" to the IC and other stuff like optocouplers and stuff and the base is that zener diode with ripped pads. You can also see R35 is in series with the diode - classic zener regulator AFAIK. Trouble is...what are these parts ? The transistor has some visible markings to help up and I made it to be 2Xx - a MMBT4401 NPN, which makes sense. Trouble is the diode: part of it has a hole punched through so I can't make out the first letter there...I think it's a J, but J3 corresponds to yet another transistor, funnily enough, not a zener. Would it be safe to try a 15v zener and cross my fingers (with the series lightbulb of course) ? It's a standard SMPS circuit - it's the motor control side that's complicated. Hopefully that part still works...come to think of it, I could probably abandon the SMPS entirely and power the secondary with a 12v adapter to see if the micro is still OK...don't think the SMPS portion interacts with the motor control side in any way as far as I can see...what do you guys think ? Pretty difficult one here :|
    Wattevah...
    • 31056
    Re: MC2100els-50w treadmill blown PSU help
    2X = MMBT4401
    NPN
    60v
    600mA
    J3 = 18v zener diode << MAYBE
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      Yeah, I found the transistor myself there, but the zener was the bigger challenge....plus other crap that might have popped and was HOPEFULLY correctly replaced
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        • Romania
        Good news: I used a 18v zener diode and since I didn't have a proper MMBT transistor on hand and due to the joint's policy of reusing parts as much as possible and avoiding buying new ones, I used a C2383 transistor botched to the board....amazingly after all this board has been through, the LED came on an I got 12v and 5v output, so my assumption was correct that it's a zener-transistor regulator. Unfortunately I can't test the motor control section, at least not easily, since it would involve a motor which I don't have and some sort of control signal for it, so let's hope the triac is fine too. My meter didn't show any shorts in any of the large components, so fingers crossed
        Wattevah...
          • 31056
          pointless equipment anyway,
          (unless you have a giant hampster )
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            • Romania
            Well treadmills aren't that uncommon
            Wattevah...
              • 31056
              proving there are lots of assholes who could just go for a fucking walk and save the money.
              • lcdcaps1
                Usb rechargeable hair clippers blown tp4056 and zener diode
                by lcdcaps1
                Hi
                all
                I have a usb rechargeable hair trimmers that should work plugged in and charge
                it stopped working no led norhing
                I've opened it up and see the tp4056 chip has blown
                There is a zener diode that I tested and get a near short ohms reading no matter which way my leads are
                I don't know what to replace this with
                Please help
                thanks so much...
                03-07-2024, 09:56 PM
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                by sam_sam_sam
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
              • nev1001
                What zener diode might fix the sound on Maestro Mayhem gaming chair?
                by nev1001
                Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                I think an issue could be a zener diode (or capacitor) which has shorted out.
                The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                04-17-2025, 05:09 PM
              • Vincenzo2
                Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                by Vincenzo2
                My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                I put some pictures here to show that it is labeled "M7"....
                09-07-2023, 07:43 PM
