Smps power supply problem
  • hgsattila
    • Aug 2018
    Does anyone have the following power supply?
    DSA-0101F-05UP: 5V 2A
    https://www.pchub.com/i/DVE-DSA-0101F-05-AC-Adapter-NEW-Original-DSA-0101F-05-UP-b-117561.jpg
    I would be interested in the value of two smd capacitors in high voltage (C2, C5)
    03-31-2024, 02:12 PM
  • shamsudeen
    Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
    by shamsudeen
    Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
    I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
    i know that in linear power supply the noise will be very low comparing to SMPS supply....
    07-19-2025, 07:14 AM
    07-01-2024, 06:34 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
