LiteOn lit on fire in HP Scanjet 5
  • clearchris
    • Dec 2013
    • 687
    Re: LiteOn lit on fire in HP Scanjet 5
    Originally posted by R_J
    Pin 4 needs a min. of 2 volts to turn on the regulator, if the opto has 5 volts across the led, the output pins 3&4 should be low connecting pin 1 to pin 4 via the 2.2k resistor.
    you could short pins 3&4 of the opto and see if the -12 is at the output of the reg.
    That's much easier than replacing the part to test. It worked! Now to replace the part.
    Thanks!!
    • clearchris
      • Dec 2013
      • 687
      Ok, I'm clearly missing something here. So I'm going back to basics.
      1. If I bridge emitter and collector of the optocoupler, I get -12v at the outputs.
      2. I have replaced the optocoupler (LTV-817) twice with PC123Y22FZ0F. I even checked the provenance of these pieces, I bought them from digikey two years ago, so they shouldn't be fakes.
      3. I have replaced the regulator since I zapped it. Woops.
      4. No change in behavior.
      5. I rechecked the voltage at the anode and cathode of the optocoupler against ground. I get 5v at the anode and 10v at the cathode.
      What should I expect to see at the cathode? I expected to see 5v or maybe a little less because the cathode gets attached to ground and maybe some voltage drop across the led, but strangely, I see 10v. What am I missing here?
      Really have to be careful in troubleshooting, I measured 5v earlier across the anode and cathode because 5 - 0 = 5 (what I assumed I measured) and also 10 - 5 = 5 (what I actually measured). Sneaky broken power supply.
      • R_J
        • Jun 2012
        • 9633
        I'm not sure what that 702p transistor is, (2n7001 mosfet?) but when the regulator turns on it will supply -12 volts to the (Source) the fault might be somewhere before the 000 and then 181 res. or maybe that line 513 res. that goes to the (gate)
        It may need power good signal to turn it on? The PG orange wire looks like it does find its way to the gate via a couple jumper wires (jp46?)
        Have you tried connecting this power supply to the scanjet to see if it does work? It may be working just fine.
        • clearchris
          • Dec 2013
          • 687
          You were right again. It did need power good to turn it on. I traced it back to the chip that does provide power good and found that the supply was only getting 3.6v when the chip requires 5-35v. That was caused by a resistor that was supposed to drop 40v to something in the range, but was dropping the voltage too much. The 330 ohm resistor must have been damaged, I replaced it and now it's working.
          Thanks!
            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-12-2024, 03:28 PM
          • CG2
            Janome DC3050 Sewing Machine Pedal Resistance
            by CG2
            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
            04-14-2023, 07:53 AM
          • osman68i
            Philips Coffee Machine PHILIPS EP5441 1.9.30.330.0
            by osman68i
            I need some advice about mainboard of Philips Coffee Machine PHILIPS EP5441 with 1.9.30.330.0
            u2 is shorted. I can only read MX1 . cable goes to display panel....
            Yesterday, 01:55 AM
          • Fam787
            HELP! A1398 Dead,
            by Fam787
            I bought a second hand Mid 2014 A1398 MacBook Pro when I lived in Australia. I'd bought it as a back-up machine because I had a Mid 2014 MacBook Pro, and realising it might one day fail, I wanted a backup machine because I don't like change.
            Two weeks after buying MBP2, the seller called me to check if everything was OK with the unit, which I thought was odd. At that stage I might have turned it on a couple of times, but I'd not used it when he'd called. Over the last few years I used the machine seldomly because my original mac has been pretty OK. Every 3-6 months I'd charge it...
            12-27-2024, 05:19 PM
          • unimatrix93
            How to stabilize AC voltage to CNC machine
            by unimatrix93
            Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
            I have a CNC machine wired to 3-phase 230V AC.
            It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
            The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
            I contacted the electricity company but they refuse to help me solve this problem.
            So I started to look around for some DIY...
            03-17-2025, 05:52 AM
