SMA Sunny Boy SB 2500 fault finding
  • snipersquad100
    • Nov 2013
    • 297
    Hi, I'm wondering if anyone know how to trouble fault this SMA Sunny Boy SB 2500.
    I know nothing about this unit, it was bought as spares or repair. I dont even know how to set it up, but this is what I've done so far. ( Not a Lot) lol
    I plugged in a solar panel, Plugged in some kind of disconnect and supplied 240v ac and nothing is coming up on the display.
    I've checked there is 240v going to the board, I don't know where it goes after that, I also cant see any fuses except the big fuse by the solar input which checks ok.
    The unit is consuming 20 watts.
    • 31063
    Re: SMA Sunny Boy SB 2500 fault finding
    the display is backlit - but it's not!
    so you probably have a missing voltage - start by checking for 5v.
    • snipersquad100
      • Nov 2013
      • 297
      I've been told that it needs 180vdc from solar string for it to operate.
      Anyone know how I can test this as I dont have enough solar panels yet.
      • R_J
        • 9551
        Is this any help? From page 11 "Activating the Backlight illumination, The background illumination is activated by knocking on the lid. Knocking once more displays the next message on the display"
        • snipersquad100
          • Nov 2013
          • 297
          Yeh your right you need to knock it to wake it up as it got a knock symble on the front by the display, "So small i didn't see it lol" but nothing happened with just the mains supply in. I really need some way of putting 180vdc to 400vdc in the pv side to test it before i go purchase more pannels.
          Does anyone know if i could put a bridge rectifier after the mains supply to give me high enough dc voltage and put that into the pv side?
            • 31063
            i would have thought it should work anyway, what if you wanted to check it at night!
            • snipersquad100
              • Nov 2013
              • 297
              Thats what I was thinking.
              • snipersquad100
                • Nov 2013
                • 297
                Any ideas why it weighs a ton?
                • R_J
                  • 9551
                  I think this is a straight inverter that takes the dc from the panels and converts it to ac, check on the ac side and see if there is a small transformer that it would use as a stand by supply, I don't think you will find one.
                  • snipersquad100
                    • Nov 2013
                    • 297
                    Oh well, I got another solar panel off my mate, Connected 3 panels in series and got 125v and it lit up, but that's all it did. I'm not sure if it needs more voltage or if it's busted. Has anybody trouble shot something like this?
                    • R_J
                      • 9551
                      I take it all 3 leds are on and not flashing? a search on the internet does say this unit did have an eeprom corruption problem.
                      h++p://forum.solar-electric.com/discussion/21956/need-repair-ideas-for-a-sma-sunnyboy-2500u
                      • snipersquad100
                        • Nov 2013
                        • 297
                        Yes all 3 led's are lit not flashing. If it's an eeprom problem then I got an interesting tear down on my hands.lol
                        • snipersquad100
                          • Nov 2013
                          • 297
                          I just found this in the manual, looks like it's initialization mode, " whats that mean "
                          • snipersquad100
                            • Nov 2013
                            • 297
                            Just found this in the manual, I need more panels. Thanks to the person who found this manual
                            • snipersquad100
                              • Nov 2013
                              • 297
                              Long time waiting but I've bought some new solar panels and I'm getting 280vdc of solar into the unit, It looks a bit more promising as its doing it's checks then it sits there waiting to connect to the grid with the green led flashing. I thought this was normal but after half an hour it still waiting.
                              I'm not sure if I have to connect a pc and configer something.
                              I've found a video on youtube with the same problem but he dont explain the fix.
                              https://youtu.be/lIAKg3Wtwtg
                              Can someone help please, I really want this up and running.
                              • jimbofz
                                just a quick question do all qled leds appear blue when fault finding ?
                                by jimbofz
                                i have replaced many leds strips that have changed blue when they are worn
                                and the new replacements are perfect white
                                but when fault finding do quantum leds always look blue?
                                08-28-2024, 06:51 AM
                                HP Compaq Elite 8200 Compaq Elite 8200 i5-2500 Specification for Upgrade or Repair
                                This specification for the HP Compaq Elite 8200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8200 boardview and Compaq Elite 8200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-12-2024, 03:36 PM
                              • Rictech
                                Panasonic SA-MAX770PU SMPSU board fault....
                                by Rictech
                                Hello everyone. 😀
                                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                There are no devices that have exploded or otherwise show signs...
                                08-26-2024, 01:05 AM
                              • howardc64
                                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                by howardc64
                                • Prior owner tried a replacement main board. No difference.
                                • Samsung 2x red blinking standby LED = panel fault
                                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                07-19-2025, 10:54 PM
                              • brainbaby
                                LG Plasma TV with no picture fault finding
                                by brainbaby
                                Hi friends,
                                This is my first post in this forum and I hope I would fetch some of your valuable time
                                Let me brief, long story short..
                                I am working on an LG plasma TV model 42PQ30R.
                                The fault is no display.
                                The tv is turning on, the blue led is working, however there is no standby (red light), tv automatically going in run mode (i.e blue led)
                                Note: sometimes gets off automatically but it happened only once or twice.
                                I began my troubleshooting with the power supply, all fuse ok.
                                power supply ok, getting the required panel voltages...
                                09-07-2020, 11:24 PM
