Re: Trouble with Daker DK 3000 UPS
It would be just a very long shot, I've never met any UPS which would have volatile memory anyway. For the usual parameters even just a few kB of non-volatile memory built into the processor is more than enough.
Hi.
Can't find any Cap that fits that description.
Cheers.Leave a comment:
Supercaps are usually very wide and short, kinda like a button cellLeave a comment:
Hi.
I've compiled a pack of pictures of this ups with more quality, it can be downloaded from http://vieirasoft.net/DK3000_Pictures.zip
Meanwhile I've tested each battery and they were all able to cold start an UPS with computer hooked on it and work for a few minutes.
The YouTube Video is not related to this UPS and curiously I had seen it before...
Couldn't find any coin type battery, how the a super cap looks like?
I've been using this multi-meter for a few years, it is not a top of the line one, but has always done the job.
I think this UPS should have an internal bypass, but if it has I've never seen it working nor I know how to activate it.
Well, here is the OM. At least there are a few comments about how to operate the front panel controls. My thought was to make sure that the micro was not keeping the unit from powering up and perhaps needs a hard reset?
Also, there might be a super cap or small coin battery for user parameter storage that is failing. Also important are details about the history of operation - such as how long was the unit in service, did it fail during a power surge, did it fail during a UPS event, and so forth.
Operation via front panel is shown here. This would make me crazy. Perhaps the software is the best way to access the features.
https://www.youtube.com/watch?v=ErZHfoDHNZgAttached FilesLast edited by Longbow; 02-20-2017, 10:14 AM.Leave a comment:
OFC there is microprocessor, always.Leave a comment:
It would be great to have at least an owner's manual for this unit. Is there a microprocessor in this unit - it might be involved in startup. You should email the factory and ask for a service manual. The worst they can say is no.Leave a comment:
As stated, if that floats above ground voltage, you can measure much more. Not all SMPSes are ground-referenced, especially on the primary side! I actually learned my lesson with some of the cheap UPSes, when there was about 100 V between battery - and earth ground
And even some which do look like there is earth potential, like APC Back-UPS RS series, there are fact some PN junctions between them which you short if you ground the batt -Leave a comment:
Your Line Voltage is 230V x 1.414 = 325V That is rectified LV without the booster circuit. When the PFC (booster) is working you should see some 400V there, but not 450V on a 450V cap. That high measurement is either user error, battery is bad in your meter, or the meter is bad. You have to use both probes on the main filter capacitor. For everything you measure in the primary section, the negative post of the main filter capacitor is your reference GND point.Leave a comment:
Isn't possible the voltage are floating against earth ground and he measured against ground, so found higher ones?Leave a comment:
"- There is a bridge of wires (blue/red/black) between the two boards labelled (GND/BUS+/BUS-) where I measured at least +450 and -450 to the GND, the multimeter overloads when measuring BUS- to BUS+. The caps are ratted 450WV/470u"
That cannot be right to have 450VDC on the 450VDC, there is really no head room at all.
Are you sure your meter is OK?
BTW, is there bypass switch to get the AC at the AC outlets of the UPS?Leave a comment:
Hi.
If I can remember correctly the DC power goes from the left board (smaller) to the right one but I don't understand the exact functionality.
Where should I measure the main filter caps, where are those?
How do I check if the PFC turns on?
It seems that the SG3525 is not generating the signals to the FETS but I don't know if this is caused by itself or if it is not "instructed" to start. I replaced it with one from a scrap UPS that I had around but it may also be bad. I'm waiting for new ones to arrive.
Sorry for the beginner questions...
Did you check the DC voltage on the main filter capacitors to see if the PFC turns on or not?Leave a comment:
Hi.
In replay to kc8adu:
- I inspected each battery and none is bulged, anyway I will test each one in another smaller UPS with some load.
In replay to budm:
- The one it that PDF it is very similar, that seems to be a newer model/design, I bet that the insides are mostly the same.
- About the heat sink, I don't fully understand this UPS (obviously), but the heat sink in the picture you referred is not the biggest, the other one that has the FETs on the other side is bigger.
- I checked all the fuses I could find (At least 8, and none is blown);
- There is a bridge of wires (blue/red/black) between the two boards labelled (GND/BUS+/BUS-) where I measured at least +450 and -450 to the GND, the multimeter overloads when measuring BUS- to BUS+. The caps are ratted 450WV/470uF.
In reply to CapLeaker:
- Yep, that is what I think about it wanting to turn on and something not letting. About it working without batteries, I think that I've seen it working without batteries when it was here to replace them, but it was a few months ago and I'm not 100% sure.
I hope my input can help you helping me.
I am curious too on what you get on the main filter caps. Sounds like it wants to turn on but it can't, so it shuts down again. If the PFC isn't working, nothing will come out on the other end. This is a online ups, so the power will be conditioned all the the time.
I have online ups's that wont go without batteries. So make sure the batteries have juice.Leave a comment:
It does not look anything like this one:
Heatsink looks too small to be for 3000VA.
https://www.badcaps.net/forum/attach...4&d=1486979341
Did you check all the fuses the main supplies board.
There are at least 4 fuses.
What are the Voltage rating of the caps that you read +/-450VDC on? Booster circuit must be working at least to get Voltage that high. to get 230V RMS, the peak to peak out has to be around 650V P-P.Last edited by budm; 02-16-2017, 08:09 PM.Leave a comment:
start by load testing each battery.
one looks bulged.
a simple cheese grater tester is fine.Leave a comment:
Hi.
About the Startup without batteries or with bad batteries, I'm pretty sure this one does: this is not a kick low price UPS, it is on-line. I agree you for off-line and line interactive UPS, if fact I know that most of those wont start without or with dead batteries.
I'm sending pictures of it, any ideas?
They don't work without the batteries, contrary to all internet rumors.Leave a comment:
This specification for the LENOVO 3000 J110 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 3000 J110 boardview and 3000 J110 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO 3000 J110...09-12-2024, 03:36 PM
by carrzkissHello, all.
Cyberpower Battery Backup Unit.
I bought two new ML18-12 batteries through Amazon (They have already refunded my money for the two batteries as we thought the batteries might have been bad.)
When I got them in, they were not fully charged. I connected them to the UPS and waited 24 hours before connecting any networking equipment.
In parallel, they read 24v, but within 24 hours, the meter on the front of the unit dropped from 4 to 3 bars on the battery charge indicator.
Checking the voltage, it was down to 22v.
I quickly removed everything... -
This specification for the ACER Predator Orion 3000 600 I9200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 600 I9200 boardview and Predator Orion 3000 600 I9200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...09-12-2024, 03:28 PM
This specification for the ACER Predator Orion 3000 PO3-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-600 boardview and Predator Orion 3000 PO3-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
This specification for the ACER Predator Orion 3000 PO3-620 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Predator Orion 3000 PO3-620 boardview and Predator Orion 3000 PO3-620 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
- Loading...
