Caps choice
  • Drack
    Yup it's me
    • Nov 2016
    • 297
    • Venezuela
    Re: Caps choice
    Yeah, I will just use the pannys and the chemicon, TK also uses teapo if I remember correctly.
    Ugh lelon
    • Drack
      Yup it's me
      • Nov 2016
      • 297
      • Venezuela
      Re: Caps choice
      Still can't find a decent solder... So recap on hold till I find something
      • Drack
        Yup it's me
        • Nov 2016
        • 297
        • Venezuela
        Re: Caps choice
        Believe it or not, but still can only find some Chinese 1.2mm solder that is extremely bad because I have one almost new
        • Agent24
          I see dead caps
          • Oct 2007
          • 4960
          • New Zealand
          Re: Caps choice
          Try a real supplier instead of eBay?
          I've bought solder from eBay twice. First time I bought some 0.4mm and 0.3mm 60/40 stuff. I don't think it's actually 60/40. Either 63/37 or Lead-free. It works pretty well though considering how cheap it was. I use it for SMDs. That was "Best' branded. eg:
          http://www.ebay.com/itm/1PC-BEST-New...-/131190008274
          I also have some 0.8mm stuff (Kaisi branded) I bought later on which also claims 60/40, probably isn't, and which has absolutely awful flux and really sucks to use. It does work, but it sucks.
          -David VanHorn
          • Drack
            Yup it's me
            • Nov 2016
            • 297
            • Venezuela
            Re: Caps choice
            Why there is no eBay over here and the best you can find is yaxun and is really difficult to do.
            I bought some solder yesterday but now I don't have much time because of the university so it will have to wait for one more week
              by momaka
              03-15-2023, 10:17 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • captain150
              by captain150
              03-16-2025, 07:34 PM
            • Foetuss
              Gigabyte GA-6OXT :: caps question
              by Foetuss
              Good evening
              I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
              Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
              But I was also suprised about the bigger boys, which are 330µF 25V.
              Could it be they used 25V caps because they were cheaper / available at that time?...
              02-11-2025, 12:22 PM
              by momaka
              03-12-2025, 03:42 PM
