Fortron 200-50SNV(PF) SFF - dead, no 5VSB
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    Hi! Today I came across an issue in one computer.
    This computer is with installed PSU - Fortron 200-50SNV(PF) SFF. When I realized that It wouldn't come on, I removed the PSU from the case and took it for testing and measuring. I found out that there is NO 5VSB - no standby voltage at all.
    Please, direct me where should I look for the problem. Any help will be highly appreciated. This PC with Pentium3 Tualatin and 512MB RAM - for one of my friend's acquaintances, which don't have enough money to buy a new one for his kids.
    This PSU is SFF, so standard PSU will NOT fit in the case. I'd rather prefer not to cut the case.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: Fortron 200-50SNV(PF) SFF - dead, no 5VSB
    Can we see some pictures? This is a very old PSU, and FSP/SPI used awful caps back in the day, most notably YEC, which would spew their guts or dry out. Start on the input side, is AC getting to the high voltage filter caps? Be careful when measuring!
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      The capacitors are mostly TEAPO and OST. None of the capacitors has bulging top.
      I have Line voltage on the input side. This is SFF, so it's divided in three separate PCB-s.
      There is voltage present between, both on the small board and where the small board is connected to the big board.
      On the big board, there is 305V DC between the two legs of the big filter capacitors, which are 2x470uF at 200V.
      The PSU worked two days ago, the PC was plugged in the power socket, and suddendly they found it completely dead.
      I don't really know what has to be the glass component, marked with B1 on the board(last photo). I've seen shottky and zener diodes in such packages. When I'm plugging the power plug, this one is arching somewhat for part of a second...
      Photos:
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        This is 2 transistor thing. In the primary, I have 1H0165R and two E13009F. In the secondary, I have KA3511, from where 5V stb is coming.(PIN 6)
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          I'd be willing to guess that the startup capacitor has failed. It's probably 22 or 47mf, 50V. Also, you should be getting about ~160V through either one of those input caps, and the voltage doubles going in to the transformer. You should replace 100% of the caps. Over 14 years, it's very possible that those caps dried out slowly versus making enough gas at once to vent the tops.
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            It's very difficult to see anything in this mess. I really don't know how they successfully put this PCB inside it's case.
            • SIDMX
              • Nov 2010
              • 165
              • Mexico
              In the 2nd pic you've posted there is a cap with some residue at the top, it could be leaking also there is no 2-transitor circuit in this PSU the 1H0165R is in charge of the 5VSB circuit so asuming the fuse is good if there is no standby you must start by checking if 1H0165R is shorted or faulty, i'm attaching 1H0165R datasheet and a schematic close enough to your PSU, hope it serves you as a guide to troubleshoot.
              Once you got it running again i strongly advice you to replace at least all output caps.
              • cpt.charlie
                • Sep 2013
                • 270
                • Spain
                Check if 5VSB is shorted, if not, most common failure is the startup capacitor like pentium 4 said (even if the cap looks fine).
                • Drack
                  Yup it's me
                  • Nov 2016
                  • 297
                  • Venezuela
                  Wait, you said b1 it's arching? That can't be good
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Yeah no kidding, how did they cram that thing in there, even with a PPFC coil. Just another reason to believe the little caps are dried out.
                    • televizora
                      ghettomodmaster
                      • Nov 2016
                      • 957
                      Originally posted by SIDMX
                      ...also there is no 2-transitor circuit in this PSU the 1H0165R is in charge of the 5VSB...
                      What the hell is this switch, that bypasses the Diode Bridge?
                      What is the mysterious component, marked with B1?
                      So, they are using 1H0165R for the standby, and they use KA3511 for everything else - they pass the output of the 3511 thru one trafo to drive the second trafo? This is such a mess. If they only used TL494...
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 5064
                        • New Zealand
                        How is B1 connected in circuit?
                        -David VanHorn
                        • televizora
                          ghettomodmaster
                          • Nov 2016
                          • 957
                          In parallel with FL2.
                          Also, when we heat the capacitors, the capacitance increases and the ESR decreases(i think). I tried to heat all the capacitors in the primary side. If the capacitor condition two days ago was enough to make it work, i really don't understand how could it be so bad, that even with heating of the capacitor, the whole thing shows no signs of life.
                          • Drack
                            Yup it's me
                            • Nov 2016
                            • 297
                            • Venezuela
                            Have you checked where do you loose the voltage? You have in the primary caps but after them?
                            • televizora
                              ghettomodmaster
                              • Nov 2016
                              • 957
                              Seems like dead standby IC. After the primary caps there is a trafo and the IC.
                              • Drack
                                Yup it's me
                                • Nov 2016
                                • 297
                                • Venezuela
                                Look for the datasheet of the IC, they have a pin where there should be a voltage, if there is probably the IC died
                                • SIDMX
                                  • Nov 2010
                                  • 165
                                  • Mexico
                                  Originally posted by televizora
                                  ...On the big board, there is 305V DC between the two legs of the big filter capacitors, which are 2x470uF at 200V.
                                  Missed this, can anyone on 230VAC mains confirm if this is right?, i'm on 115VAC so no idea.
                                  Somehow I missed this, it looks like a glass discharge tube (GDT) but not sure, IF it is a GDT it should only "arc" under surge conditions so it maybe be faulty and it could potentialy killed 1H0165R but i'm just guessing you need to test the IC ,also as others have said check/change the startup capacitor.
                                  It's not that complicated really, 1H0165R is a PWM + FET and switches the SB transformer, it's output feeds KA3511 which is a PWM + SMPS supervisor (think of it as a TL494 + LM393 in one package).
                                  Exactly, you should check if there is proper voltage at Vcc pin
                                  • televizora
                                    ghettomodmaster
                                    • Nov 2016
                                    • 957
                                    ....also as others have said check/change the startup capacitor.
                                    In the schematic, where the start capacitor is? I only see 1H0165R, which is self-sufficient and it directly uses the input voltage after the filter caps.
                                    And yes, I think it's the way it should be - about the voltage on the filter caps.
                                    230 is effective, not maximum. When we rectify it, we put the sine on the positive side of the coordinate system. These half-sines are smoothed by the filter caps to the maximum amplitude voltage,which is 230*1.41=324V
                                    • SIDMX
                                      • Nov 2010
                                      • 165
                                      • Mexico
                                      The cap is immediate left from 1H0165R and it's labeled C28
                                      • televizora
                                        ghettomodmaster
                                        • Nov 2016
                                        • 957
                                        The cap is immediate left to 1H0165R and it's labeled C28
                                        Will have to remove the 1H, the heatsink and the other 2 transistors. Oh, hell..
                                          ASUS E410MA-BV190TS-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS E410MA-BV190TS-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E410MA-BV190TS-CASE boardview and E410MA-BV190TS-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 10:50 PM
                                          ASUS 571GT-AL188R-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS 571GT-AL188R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 571GT-AL188R-CASE boardview and 571GT-AL188R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 11:05 AM
                                          ASUS X712FA-AU306T-CASE Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS X712FA-AU306T-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU306T-CASE boardview and X712FA-AU306T-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS VivoBook X712FA-AU311R-CASE Notebook 17 Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook X712FA-AU311R-CASE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X712FA-AU311R-CASE boardview and X712FA-AU311R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) Flip Specification for Upgrade or Repair
                                          This specification for the ASUS ZenBook UX461UN-E1042R-CASE Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX461UN-E1042R-CASE boardview and UX461UN-E1042R-CASE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 07:07 AM
