Burned Components on LCD Monitor Power Supply ILPI-178 ILPI 178 (Samsung 943NW)
  • Folxs
    • Nov 2016
    • 167
    • Poland
    Hi, I got burned some parts on ILPI-178, I tried to find schematic and values for that components on the board.
    Can anyone help me?
    Thanks!
  • jondoe
    • Nov 2016
    • 547
    Re: Burned Components on LCD Monitor Power Supply ILPI-178 ILPI 178 (Samsung 943NW)
    Is this the same model?
    https://cdn.badcaps-static.com/pdfs/...eea2c8ca67.pdf
    • jondoe
      • Nov 2016
      • 547
      Also
      http://monitor.espec.ws/section33/topic201025.html
      • Folxs
        • Nov 2016
        • 167
        • Poland
        Thank You very very much! I have ordered all the parts!
        • jondoe
          • Nov 2016
          • 547
          Good luck! Let us know how you get on ��
          • Folxs
            • Nov 2016
            • 167
            • Poland
            It took some time, but all the parts arrived!
            LD7575
            R813 = 20Ohm
            Q804 = AP2761i (I got installed 2763I, but in the schematic was also 2761, so I installed that)
            R809 = 680Ohm
            R815 = 0.47Ohm/2W
            IC801 = PC817B
            I checked all this part and they all were blown - they are all red on service schematic
            Thanks for help!
              • Jul 2011
              • 6046
              Is that photo of monitor that has the windows logo on it is that one you repaired
              If so good job another one that was saved from the land fill
              • Folxs
                • Nov 2016
                • 167
                • Poland
                Yes it is - i made picture to show that this is working again
                Thanks!
                • Behemot
                  • 4845
                  • CZ
                  Wasn't the bulk cap bad? Usually it's because of the cap why the switching section fails.
                  • Folxs
                    • Nov 2016
                    • 167
                    • Poland
                    Bulk cap You mean big cap for 400V around 100uF or that small cap, that is setting frequency of inverter?
                    • Behemot
                      • 4845
                      • CZ
                      The big one on the input.
                      • Folxs
                        • Nov 2016
                        • 167
                        • Poland
                        Actually both were ok
                        This failure was because of storm and lighting hit nearby.
                        • Behemot
                          • 4845
                          • CZ
                          IC. Can't find a varistor so it has no over-voltage input protection.
                          • Folxs
                            • Nov 2016
                            • 167
                            • Poland
                            A lot of monitors have place for varistor but it is not installed
                            • Behemot
                              • 4845
                              • CZ
                              There does not even seem to be the place for it here You may still make some with a thin drill though.
                                09-07-2024, 05:50 AM
                                by momaka
                                03-15-2023, 10:17 PM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
