DVD player power supply stuck in standby.
  • Wizard
    • Mar 2008
    • 2296
    NCP1216P065 7 pin package (8 pin dip with missing pin), MOSFET switcher, blah blah.
    Standby and run mode use same cold side 5V and power supply base on it for regulation via optisolator to switcher IC.
    But one thing that is driving me NUTS is this thing will NOT come out of standby mode due to PNP transistor not switching completely off from 40V supply disconnecting from 5V. PNP base is pulled up by 40V supply via bias resistor and it's not pulling all the way up with transistor in place. Unsolder emitter or collector of PNP and power supply comes to full power. Tried another PNP transistor with no luck and even I measured disconnected base signal for PNP and it's swinging enough.
    The PNP is driven by pair of NPN transistors (inverts the power control signal from high to low via the current limiting resistor and divider on the PNP's base.
    And that circuit is working as it supposed to be.
    What this insane idea is that designer used 40V supply via PNP transistor onto 5V supply is to "trick" the regulation and enter into low power mode by forcing 40V down to 6Vish (measured) via the PNP transistor to 5V supply.
    SIGH. Totally stumped. The microcontroller is switching the power control up and down properly. Help?
    Cheers, Wizard
    03-31-2024, 02:12 PM
  • Yanleb
    UN65MU6300FXZC, no standby LED but power supply good. Bad IC1604 25Q40?
    by Yanleb
    My UN65MU6300FXZC is dead and the standby LED stays off. The power supply is good. The main board is BN94-12434A.
    Disconnecting the main board from the power supply makes the backlight come ON.
    I did disconnect the panel cables and the WIFI modules, the board is still dead.
    I did read in many posts that IC1604 25Q40 becomes corrupted. It has proper 3.3 volt on VCC pin 8. I did read that if I post its dump here someone can fix it. Is that right?
    Thanks.
    11-18-2024, 12:34 AM
  • reessi
    JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
    by reessi
    I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
    You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
    Years ago it had some bulging caps...
    04-26-2021, 11:42 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    07-01-2024, 06:34 AM
