FSP300-60GLS overheating problem
  • Behemot
    • 4845
    • CZ
    Oh man! Just when I NEED these units fast and I don't really have the time to waste for one not working, one is not working! The GLS is basically a scaled-down version of Blue Storm II (GLN).
    Just did full recap and one of these is behaving like it is overheating: after a wile on the load, the voltages start oscillating and than it turns off. The stand-by is at stable voltage the whole time. If I turn it on again it happens within a few seconds. So definitelly an overheating problem. Any idea what may the problem? Fan controller? As far as I found, this has no OTP.
    When something is too hot inside, it even does nto want to turn on for a while.
    • 31028
    Re: FSP300-60GLS overheating problem
    did you remember FSP like to hide a couple of small caps in black sleeving?
    • Behemot
      • 4845
      • CZ
      Two crapxons KF 1000/16, both replaced. The input caps seems OK too (have not replaced this one).
      It is actually strange as it seems it is maybe not fully temp dependent. Or at least not surface. Sometimes it behaves like dying animal - starts making mess, voltages drop to like 1/3 of nominal, oscillate till it finally turns off. But that it twists a few times, sometimes even for a few seconds. The same is happening even when I turn everything on my load off, only keep the fans running (about 28 W). With such low load, anything on the surface should be OK. I am thinking maybe it really is shorted transformer this time? I noticed it was running quite hot…it would make sense, the transformer heats internally.
      Otherwise I checked it twice already, nothing wrong visually. Resoldered couple joints but still nothing.
        • 31028
        failing diode?
        maybe freezer spray would help.
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8161
          or some resistor going high in value while under load.
          • Behemot
            • 4845
            • CZ
            Well yeah, which one? There are tens of those things…
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8161
              also could be a cold solder joint on the inductors of the secondary. You need to probe around with the oscilloscope and see if only one voltage rail or all of them going nuts (not the STBY voltage).
              Which one? I dunno... didn't see the PSU or a schematic. Start at the mosfet driver and the feedback circuit. I posted some switching PSU repairs here on badcaps. There was a cold solder on a inductor, a bad voltage dropping resistor that went high in value that fed the Mosfet driver, a bad cap on the feedback circuit etc, just for ideas.
              • Behemot
                • 4845
                • CZ
                I resoldered the 3.3V inductor, the rest seems OK…
                • Behemot
                  • 4845
                  • CZ
                  Tiny update. I've let it run just with the fans. It is so low load nothing inside should get anything but warm in worst case. Problem also appeared, just later. I do not think it is heat, or heat alone.
                  I also checked the voltages, all output rail were down (+3.3 V was higher but there was no draw from it, with 1.5 A draw it dropped quickly). The Power good signal dropped out as it should so at least the supervisor is somewhat working.
                  • Behemot
                    • 4845
                    • CZ
                    Got another troubling unit, this time the SB does not work at all. Think I will use one as donor and try replacing components one by one to see what happens. Starting with DM311 maybe?
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8161
                      You should be able to make out of those two one working unit no problem.
                        • Jul 2011
                        • 6039
                        Did you get any where with this power supply ?
                        • Behemot
                          • 4845
                          • CZ
                          Not yet, it has low priority right now.
                          • harii07
                            • Aug 2016
                            • INDIA
                            Hello all, I am about to repair FSP460-631U SMPS. I need service manual or circuit. Any on have this or any direction. Please
                            • AJ847.63e
                              Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
                              by AJ847.63e
                              Hi Folks,
                              Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
                              I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
                              The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
                              05-06-2025, 10:37 PM
                            • Zeonalbasta
                              Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                              by Zeonalbasta
                              i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                              The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                              09-13-2024, 01:17 PM
                              HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                              This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                              09-12-2024, 02:20 PM
                              HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                              09-06-2024, 10:56 AM
                              HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                              This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
