Antec SP300 fails again!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8716
    After fixing it the first time around from https://www.badcaps.net/forum/showthread.php?t=24113 the old venerable PSU has failed again! Well, not totally dead. I had been powering a Prescott 3GHz with 5 HDDs with an onboard GPU. It had trouble powering up the system at first (would cycle) but eventually it would come on.
    However it had came on the last time. Now it won't power up any more. Yes I think this system might have been really pushing a 300W PSU.
    Anyway, 5VSB still looks good, and... if I short the green wire to GND, it will turn on just fine when the PSU is not plugged into a motherboard!
    Swapping this PSU with the repaired SP400 powers up the P4 machine so something strange is going on... Perhaps one of the secondary diodes gave up?
    (BTW Anyone seen PeteS in CA recently? Haven't seen any of his insightful posts in a while.)
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Antec SP300 fails again!
    Pete is long gone he quit BCN ages ago. Sounds like a bad feedback cap issue to me have you esrd the caps ?
    • valvashon
      LG 55UH6150- trouble powering up, then half lit screen (pictures!)
      by valvashon
      The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
      Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
      11-24-2024, 12:08 PM
    • DarKHawK
      Asus 2021 ROG Strix G17 G713 not powering on and not charging.
      by DarKHawK
      I have an Asus 2021 ROG Strix G17 G713 that is not powering on and not charging. Board number is G533-6050A3250201.
      When plugged in, I found that the 3.3v/5v regulator was getting extremely hot, so I removed, next I found a short on the 3.3V rail. Removed the two 3.3v mosfets and found one of them shorted, but still the short on the rail did not clear. Then I injected voltage at that rail, and found out that U60400 the 2.5v rail was also getting hot. Removing it changed the short from 0 ohms to about 5-6 ohms, then I remove a bunch of other suspect components but that did...
      07-11-2025, 05:24 AM
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
    • ShadowAi12
      ASUS ROG STRIX B550-F GAMING — Board not powering on properly
      by ShadowAi12
      I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
      • The board enters a "ready to power on" state after plugging in the PSU.
      • Pressing the power button increases power draw.
      • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
      Measurements:
      (taken after pressing the power button, while the board is attempting to start)
      • H_SKTOOC#
      06-11-2025, 01:05 PM
    • TechSplendid
      MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
      by TechSplendid
      Hi All,
      I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
      Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
      04-09-2025, 02:13 AM
